Airbeatz 505 lower volume on bluetooth - Office Equipment & Supplies
Where is the volume
Little buttons on side of headset. Typically the factory setting is for right ear. So volume button on top would be up volume and bottom would be lower volume.
Mark
Motorola Support
May 20, 2014 | Motorola Mobility H371 Bluetooth Headset
Peltor MT53H7AWS2 Bluetooth Headset pairing instructions
• Establish the Bluetooth link between the headset and another Bluetooth device by pressing the raise volume (+) and lower volume (-) buttons simultaneously for at least two seconds. Note that the headset must be switched off while you do this!
Some models of mobile phone require a pin
code in order for the mobile phone to identify the
headset. If this is required, enter four zeroes (0000).
This applies to all Peltor WS headsets and cannot be
changed by the user.
Nov 07, 2012 | Peltor MT53H7AWS2 Bluetooth Headset
Motorola h730 low volume
press the two buttons on upper and lower side while it is connected to your phone
Jul 04, 2012 | Motorola Mobility H730 Bluetooth Headset
Hi, guys. I recently bought a Nokia BH-505 bluetooth headset. I succesfully connected it to the phone (s Galaxy S) and used all its features but i cant connect it to the pc. The pcc just doesnt see it. It...
Hi Bogdy_3003,
I see that you are having issue with your BT Nokia headset.
You mentioned that you are having issues connecting it to our PC.
You need to make sure that the Bluetooth settings on the computer is set to allow other devices to detect the computer to be able to get your Bluetooth Nokia headset working with your computer.
Look for the Bluetooth icon on the lower right side of the taskbar somewhere near the time then right click on it then select open bluetooth settings, it should open up a window for the Bluetooth on your computer then look for "Allo other devices to detect this computer" and put a check on it, click on Apply or OK, this should make your computer be detected by other BT devices such as your Nokia headset.
I hope this will help.
Have a nice day,
mvincentc
Jun 21, 2011 | Nokia BH505 Bluetooth Stereo Headset
Volume of internal speaker suddenly much lower than before. Volume OK when speakerphone turned on or when using Bluetooth headset.
Look for the volume key on the side of the phone, depending on the model of you phone it could be anywhere. post the model so I can show you.
Thanks
Feb 17, 2011 | Cell Phones
How to conect BH-505 to nokia N8 booth are new
can i connect bluetooth headset BH-505n N8 mobile
Feb 10, 2011 | Nokia BH505 Bluetooth Stereo Headset
Hello I have just bought a Nokia Bluetooth stereo headset BH 505 and I can't find the pin code number. Where is it written please ?
Hi,when you want to connect a Nokia Bluetooth stereo headset BH 505 to a phone all you need is a default code which "0000" and your done Try it it works like magic...Or you can choose to useany other code, but the code must be 4 digits.....
Thanks for using fixya...............
Jan 06, 2011 | Nokia BH500 Bluetooth Headset For N95 8GB...
I RECENTLY PURCHASED SAMSUNG WAVE MOBILE S8500 AND ALSO NOKIA BH 505 BLUETOOTH HEAD SET. WHEN I TRIED TO PAID THE BT HEAD SET WITH THE MOBILE. THE MOBILE PHONE IS NOT RECOGNISING THE BLUETOOTH HEAD...
ya i have bought bh 505 yesterday and i am using samsung wave s8500...i have connected my phone with bh 505....its very easy...while turning on your bluetooth headset you have to press and hold for long time till a blu light appears then you turn on bluetooth in your phone and search...it will recognise and pair the device...thats alll ucan use it now...itss awesome....
Nov 10, 2010 | Samsung Bluetooth?® WEP200 Headset...
Volume control problems with motorola bluetooth stereo headset. Sometime volume switch won't respond to lower the volume and at other times, the headset beeps and then volume decreases on its own.
may the problems also lies with the connection between handset and stereo. may it has lost its service. try getting another one. good luck!
Oct 14, 2009 | Radio Communications
27 people viewed this question
jasbo
jasbo
