Question about Jenn-Air JCB2285KES (21.5 cu. ft.) Side by Side Refrigerator
Refrigerator side keeps going to 18 degrees. How can I reset it to factor spec 38?
Temperature wont set above 32
*sigh* Yet another bad Chinese made motherboard.
Mar 13, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature of thermo defrost samsung
If the dial is in such a format in your refrigerator, try a setting at 3 if the range is 1-5, and at 4 if the range is 1-9. For the freezer, a setting at C is suitable.
The ideal temperature in the refrigerator ranges between 34 - 38 degrees F or 1 - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrress C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower. See more at:
http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 01, 2014 | Refrigerators
Electricity off want to reset temperature. What should frig and freezer be set?
Temperatures are preset at the factory at 38 degrees or 3 C in the refrigerator compartment and 0 degrees F or -18 C in the freezer compartment. Here is a link=> MFI2067AES User Manual to the user manual for your model that explains how to set the temperature, I am here should you have questions Thanks Sea Breeze
May 29, 2013 | Maytag MFI2067AES Stainless Steel Bottom...
My GE Adora seams to be breaking down. Freezer is not freezing and temperature in both, Freezer and Refrigerator is dropping. HAVE reset the temperatures to GE's recommendation of 0 Degrees and 38...
One thing you can do is make sure condenser coils have plenty of area around them (nothing lying against refrigerator) to prevent air flow. If possible vacuum and clean condenser coils and make sure freezer door is completely closed.
Aug 01, 2017 | GE Adora (DSF25KGTBG) Side by Side...
My dometic refrigerator is not freezing properly. it is a model 1062-ndr. the ice cream will not stay hard and the temp in the freezer is 18 degrees. the refrigerator part is o.k. and temp is 38 degrees.
If the refrigerator is 38 degrees and the freezer 18 degrees , both are not normal.
Have you used any hard and pointed object to remove any frozen food or Ice before this happen?
Have you notice any oily part coming out in the freezer or at the back of the refigerator which will indicate that there was a leak?
there are few factors that may cause your refrigerator to be like that:
1. A possible leak along with the tubing that will cause to loose the refrigerant which make the refrigerator to produce ice.
2. lost Compression (Motor compressor) this happen eventually specially the refrigerator is more than 10 years old
the best way to find out is to call a technician and have them check it
Nov 06, 2009 | Dometic NDR 1062 Refrigerator
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
What temp should the fridge and freezer each be?
According to FDA safetey specs bacteria can grow at 40 to 140 F degrees .Refrigeration must be below this number but above 32F to keep from freezing. I maintain commercial refrigeration and they run at 34 to 38 F degrees. I have deep freeze set at -10F which keeps ice cream very solid but can go up to +2 F which renders softer ice cream...
Jun 25, 2009 | Kenmore 64802 Top Freezer Refrigerator
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Jenn-Air JCB2285KES (21.5 cu. ft.) Side by Side Refrigerator Logo
20 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
