Question about Majestic Car Audio & Video
I have a Majestic MEB 1070S 7 band car equalizer I need the wire diagram
SOURCE: Automax 7 band car equalizer
hola, first have tranlate for spanish a english, mira yo tengo el mismo ecualizador, las entradas son (input) el rojo (red) es (+) y el negro (black) (-), el verde (green) es el canal izquerdo (left) y el gris (grey) es el canal derecho (right) eso es toda la entrada, los comunes o los negativos de las salidas del stereo no se conectan (las salidas del stereo tienen que conectarse como si fuera un sistema de solo 2 bocinas a la entrada del ecualizador), las salidas (output) serian azul (blue) comun izquerdo (L-),blanco (white) izquerdo frontal(+ front L), cafe (brown) izquerdo trasero (+ rear L), naranjo (orange) comun derecho (R-) ,violeta (violet) derecho trasero ( + rear R), amarillo (yellow) derecho frontal (+ front R)
para que quede mas claro
input:
red (+)
black (-)
green (L)
grey (gris) (R)
output
Right
violet (Rear)
yellow (Front)
orange (-) R comun
Left
brown (Rear)
wihte (blanco) (Front)
blue (-) L comun
ojala que este post aun te sirva, saludos desde Chile
Posted on May 30, 2008
SOURCE: Optimus 7 band equalizer model # 12-1969
I need to know what the wire are coming out the back of the optimus seven band stereo frequency equalizer/booster
Posted on Nov 27, 2008
blueextc3221
  • 15935 Answers
SOURCE: need wire diagram for clarion 500EQA equalizer
Your installation manual is not anywhere to be found since the product you are inquiring about was made 1985-87... however, by deduction, you can figure it out yourself...
You need a Power 12V Constant.
A 12V Switched
A Ground
And Signal Cables.
Reply with the wire colors available to you, and I will tell you what is what.
Yellow is usually constant 12V.
Red is Ususally switched 12V.
Black Is Ground.
RCAs are self explanitory.
If your EQ has HI Level outputs, the color scheme is a little more complicated.
Posted on Jan 10, 2009
  • 430 Answers
SOURCE: I need a wiring diagram & detailed
Open the vac by removing 3 screws below the handle area and the long screw at the bottom of the cone. If the motor has been removed, you will have 2 motor leads , 2 power head socket leads, and 2 switch leads as well as the cord. Do not twist your wires first when pairing, twist with the wire nut ony and tape afterword as there is metal nearby in the housing area
1 side of the cord goes to the switch only. The opposite side of the switch will go to 1 of each of the motor and Socket. The remaining motor and socket leads pair with the remaining cord lead.
While you are in there change the round filter dic covering the front of the motor and you could change the foam/ felt wrap around the inside of the housing.
There is a insulating disc at the top of the motor to prevent shock between motor and screen. Do not remove it.
Posted on Sep 08, 2009
  • 436 Answers
SOURCE: don't know how to install equalizer. Where does
hi input wiring hooks up to speaker wire outputs on the stereo. in 2008 chrysler has no ignition or accessory outputs. everything is digital, if you use a trunkloc from PAC electronics you will be able to hookup your outputs from the deck into this unit and it will provide you with the RCA, and remote power output needed for your system to operate. the factory deck should have battery and ground at the plug but no acc.
Posted on Sep 23, 2009
Wiring details for alpine3215
Wiring connection diagram. For Alpine 3215 7-band graphic equalizer with 4-amps. have custom scanned this item for those folks that don't have a need for the full service manual and just need a simple connection diagram. Includes wiring connection diagram and pin-outs of the din as well as output block connectors.
Sep 28, 2016 | Car Audio & Video
Need wiring diagram for alpine graphics equalizer
Hi there
Use the 'Google' search engine and type in support.alpine-usa.com/products. You will be able to download a pdf manual on your model.
Apr 13, 2014 | 1993 Ford Probe
Need wire diagram for pioneer eq-6500
Pioneer EQ-6500 9-Band Car Equalizer .i want to buy this equaliser.i need 10 pieces ,please send me through my email febiano22@yahoo.com
Nov 24, 2010 | Pioneer EQ-6500 9-Band Car Equalizer
I need a wiring diagram for the pyramid 10 band graphic equalizer. Where can I find this diagram?
Click on MANUAL DOWNLOAD
LOOK PAGE 4 INTO THE PDF FILE!!!!
http://www.pyramidcaraudio.com/sku/903G/10-Band-Half-Din-Power-Booster-Graphic-Equalizer-Amplifier-200-Watts#
Oct 10, 2010 | Pyramid 903G 10-Band Car Equalizer
I need a wire diagram for equalizer 903g
Jan 29, 2010 | Pyramid 903G 10-Band Car Equalizer
Need wireing diagram for pioneer deq 7600 4pin plug
I need to see a diagram how or how to setup my equalizer and reverb to my amp all pioneers old stuff sg60 and sg540
Jun 28, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Help
red -power
black/casing - negative(ground)
orange-is memory/ignition on
the rest are right'left outputs
Sep 19, 2008 | Pyramid 403G 7-Band Car Equalizer
Wiring Diagram
Did you get this figured out?
Apr 28, 2007 | Hitron SEQ-554 7-Band Car Equalizer
Car Audio & Video Logo
48 people viewed this question
Top Majestic Car Audio & Video Experts
xxxxxx xxx
Are you a Majestic Car Audio and Video Expert? Answer questions, earn points and help others
