Whirlpool washing machine
Agitator will not turn. It is loose. I took it off but there was nothing underneath it to tell me what the problem is.
  • 1 more comment
  • Krush Nov 25, 2007
    I have removed the top agitator and it appears the dog ears are worn. How are they removed?
  • TXgal7 Dec 03, 2007
    The agitator on my machine doesn't seem to want to turn completely, it just takes mini motions and every now and then turns fully. My washer machine is a Kenmore 80 series model #23822100. And it makes the lights dim every time it tries to turn. Can you help?
  • K Lab Dec 15, 2007
    I can hear the motor running and the water fills and drains fine. The agitator just seems to shake back and forth but it doesn't move the clothes. The rinse and spin cycle seem to work fine. Basically it fills with water and will sit there shaking through the cycle and then emptys itself. It then rinses and spins. HELP!!!!!!!! I need step by step instructions to help to fix this problem.
  • 447 Answers
Is the top part of the agitator not moving but the bottom part is??
Posted on Sep 27, 2007
SOURCE:
Clothes & sheets get wrapped in agitator and it makes a loud noise in my Whirlpool wtw4800xq1
Here is a video on how to change a part that could be part of the problem, the video shows how to remove the agitator so that you can remove the clothing that is jamming the machine, http://www.repairclinic.com/PartDetail/Whirlpool-Washing-Machine-Agitator-Repair-Kit/285809/470910?modelNumber=WTW4800XQ1&ss=a11b5d956381&mr=1
Jul 30, 2016 | Whirlpool Washing Machines
I want to remove the Agitator. User Manual says 10mm bolt inside Agitator. But it doesn't Undo or Tighten- DOESN'T feel like its stripped -Could Drive shaft just be turning with bolt? Ron
You will have to hold the shaft underneath while you turn it, most likely it came a bit loose, but is rusted holding to he shaft, but no longer to the agitator.
Mar 17, 2015 | Washing Machines
Machine not agitating
The most common cause for the agitator not spinning is a broken drive belt. If you are able to turn the agitator by hand, the belt is likely broken. If the agitator cannot be easily turned by hand, there is likely a piece of clothing jammed underneath and the agitator will need to be removed to clear the jam. The video below will demonstrate the procedure for replacing the drive belt in most Whirlpool washers.
Dec 29, 2011 | Whirlpool WTW5500X Washer
My Whirlpool LSR8233EQ0 washing machine making loud whining and banging noises during spin cycle only...any ideas on what to replace?
Two possibilites would be a loose agitator (some agitators can betightened from the top, check for tightness)If you can't tighten the agitator from the top, turn the machine over ( you will probably need to disconect water hoses first) and check the underside. From here you should be able to determine if the agitator is loose or more likely you've got a loose drive belt.
Nov 16, 2011 | Whirlpool Washing Machines
Washer will not agitate or spin - still fills and drains
check the peice underneath the motor it is a plastic peice. and then check the dog ears inside the agitator. thats what i had to replace and it cost about 30 bucks. and took about 30 minutes.
Sep 19, 2011 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool washer not draining
most top loaders use belt drives, it sounds as one of the belts has snaped. can you see a belt laying around a pully or on the floor of the washer that has come away , or a pully with out anything to turn it.
May 14, 2009 | Admiral AW22 Top Load Washer
Removing old dogs to replace them
Take pliers and pull it hard. It will come loose.
Apr 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
Kenmore 80 washing machine won't agitate
remove the agitator to see if there is a coin or bobby pin wedged underneath.
Dec 26, 2008 | Kenmore 24902 Top Load Washer
Loose agitator
Remove the center dispenser. Under the dispenser is a plastic cap with a pull handle on it. Pull the cap straight up and you will find a mounting bolt underneath. Using a socket and ratchet, tighten the bolt snug. DO NOT overtighten as this may cause damage to the agitator. If you go to searspartsdirect.com and type in your model number, there is an excellent exploded view diagram of the agitator components under the "Agitator, Basket and Tub" heading. If you still require assistance, please let me know. I hope you find this information helpful.
Sep 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
222 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
