Question about Panasonic Portable Slim Line Cassette Recorder Rq 2104
I just bought an old cassette play it's a panasonic slim line player with an orange reddish record button built into the play button. Anyways, I had a blank cassette that i have used before to record stuff onto. So i am sure it is not the tape that i was using that caused this problem. anyways, when you press the record button the play button needs to be pressed down as well anyways when i was finished recording I tried to press the stop button (which is supposed to stay down when you press it. So what is happening is the stop button will not stay down. The record button came back up but the play button has stayed down. The eject/pause will only pause and not eject (it will stay down.) anyways that is pretty much the problem. i forcibly pulled the tape out to try to figure out the problem and i am not able to put it back in. it went back in once but when i pressed play nothing played and i love my cassette player and I just want it to work. so if you know what is wrong please try to help me out.
  • 169 Answers
SOURCE: Panasonic NV-DS27 - "playback blank"
try to clean the video head using a blank new tape and fast forward it 5 times if needed...dont use a video cassette cleaner it will ruin your video head...
Posted on Aug 10, 2007
SOURCE: playback problems - timer stays at zero
mi proble is: the power is gone, no power in the camara
please giveme a solution att. norman mejia
group A 893
group B 5889
group C 511833
val # 0294-2802-9294-4641
I
Posted on May 11, 2008
SOURCE: panasonic dvr d 200 hand camera - the recorded disc doesn't play on regular dvd player
First I must say I have different camera, but in my case I must close the disc session from camera menu, so theat after it dvd could be played in dvd players and after it you can't record on that disk anymore. If you alredy know that, then sorry. I have a problem that some non-scratched in any way disks with data just don't respond at all, but that's another story. All the best.
Posted on May 21, 2008
  • 3 Answers
SOURCE: PV-GS9 mini dv playback problem
I covered several threads that recommended buying a Mini DV cleaner and running it up to 4 times. They also suggested to change to change your video tape as it may have been the cause of the original problem.
These solutions may have worked for many but not me. My camera was becoming progressively worse. It went to blue bars and no sound to no picture at all...just blue. After using a cleaner 4 times I became frustrated to the point I was going to buy a new camera.
However, with the camera still playing, I did the typical guy thing and rolled up my fist and gave it a good hit along side of it. Remarkably it went back to just the blue bars. I hit it again and it went back to a perfect picture. I'm not saying this will work for you and hitting it too hard could make things worse but I was at a point where I didn't care any more and took a chance that paid off.
Posted on Sep 21, 2008
  • 136 Answers
SOURCE: how to pre-set radio stations panasonic radio/cd/tape recorder
the best thing would to go to the panasonic web site and they should have the solution. they might even have the manual for it. without a picture this is the best i can do.
Posted on Apr 01, 2009
HOW DO I SET UP MY KENWOOD MINIDISC RECORDER
A MiniDisc recorder would plug into your stereo system just like a regular old cassette recorder would. Line out from deck to line in/play on receiver/amplifier and Line In from deck to "record" / tape line out from amplifier/receiver.
Insert MiniDisc, select Source and you should be ready to hit 'Record' and then 'Play' to start recording.
Mar 04, 2016 | Audio Players & Recorders
Cassette Recorder play problem
It is problem in Take-up Reel section and its not sending signal to processor. How old is this unit?
Jul 24, 2008 | Onkyo TARW255 Single Dual Cassette Deck
Recorder button does not go down. . Is there anyone who knows how to fix this problem
There is an interlock that prevents accidental recording. You may have to press PLAY and RECORD at the same time.
Jan 01, 2015 | Sony Tcm939 Table-top Tape Cassette...
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Record button will not push down with play button, to record.
Are you using a new cassette???? Check to see if the tab is missing on top of the tape.....If it is put tape over it
Mar 14, 2012 | Memorex MKS5009 Karaoke System w/CD/CD+G...
I have an old Pansonic RX-DT680, the model were the speakers detach. Can I record from tape to CD ?
The built in CD is just a player not a recorder and the unit does not have line level outputs to run to an external CD recorder so the answer is unfortunately "no". You could use the high level speaker outputs and "pad" down the outputs to line level using a pair of potentiometers, one for each the left and right channels, if you have any electronic wiring knowledge.
Nov 28, 2010 | Audio Players & Recorders
Can I record from a cassette player to the koss
should be able to go directly from tape out of cass deck to input of your koss, as long it has line level inputs (which it should). from there its play on the tape and record on the cd rcrdr. seems the simplest solution
Jan 30, 2010 | Koss CDR200 2-Disc CD Recorder
An elderly relative has lost a panasonic rq-sx53 stereo cassette player. He has many recorded tapes he likes to listen to. Can you advise alternative models which will play these c90 tapes??? The...
Look in your area for any good cassette player they all can play the c90 tapes. All you have to do is have a cassette player. Large stores that have stereo dept. would be a good place to look where you can also hear them to see the sound quality.
Sep 08, 2009 | Audio Players & Recorders
How do I tape to tape
you mean to record?first,you must connect the other unit (if you are using two cassette)by using rca plug or earphone plugs.insert the plugs to audio in or aux(this is the unit that will record).if the other unit doesn't have the output audio,use the earphone out instead.time to record.the recorder must be set to tape/aux,(if you are using a unit with radio setting).then,push the play and record button at the same time.don't forget to put in the blank tape ok.then push play to the unit that you want to be recorded.the square symbol is for stop.the arrows pointing left ,rewind.pointing right, forward.the big arrow pointing right is the play and the button next to it is the record button.
May 14, 2009 | Panasonic RX-D29 Radio/Cassette/CD Boombox
Panasonic Portable Slim Line Cassette Recorder Rq 2104 Logo
73 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
