Question about Longines Watches
Replace back plate - Longines Watches
How to re-close the back plate on a Dakota time/date warch?
Some of these watches have a notch where the stem goes. If you don't have the back in place it will not snap back into place. Also some are a slight screw back and will snap off, but when putting them back you must kind of screw it back in place. Good luck.
Jan 28, 2015 | Dakota Watches
I cannot replace the back of a timex 1854 watch. I replaced the battery but the back won't click on
I used a four inch "C" clamp and a large washer about diameter of back, to get my Timex back snapped back on. Place the watch face side down on a flat surface cushioning the crystal with soft rubbery material like shelf liner or anti skid material used under rugs (the kind used to also line tool chest drawers - black). Place the washer between the watch back plate and the "C" clamp screw plate. Align the back plate of the Timex as evenly on watch as possible while gradually tightening the "C" clamp. Keep turning down the "C" clamp ever so slowly until you hear the plate snap back on.
Jun 28, 2011 | Watches
The word (op en) on the top in place of the date or the day and nothing is responding
I had this problem and managed to fix it. There is a small metal plate locate inside the back cover of the phone that can be knocked out of position. The small plate should be in contact with the two screws in the top right hand side of the watch (when back plate is off).
To remove back plate you must remove the strap. To do this you must remove the four pins that connect the strap to the watch body. Take out the pins and set aside. The two plastic inserts can now be removed.
Remove the four screws and remove the back plate. Be careful not to lose screws, rubber seal and small plate.
Reglue the small plate to back plate and allow to set.
Reassemble watch in reverse order and watch should work as normal.
Good luck
Feb 27, 2011 | Casio Protrek Triple Sensor PRG70 1BVDR...
Battery replacement
Hi.
Battery replacement is done removing the back plate. The back plate is uncrewed clasping it with a special tools and rotating anti-clockwise. In absence of the special tool a common pair of tweezers will do the job.
Once the back plate is off, extreme care must be taken with the rubber seal, running around the edge of the case opening. This is very delicate, and damaging or kinking the seal may result in the watch loosing its water proof capacity. For this reason battery replacement is better done at the shop.
Here casio page for this model:AMW320R-
Sep 28, 2010 | Casio AMW320R 1EV Casual Sports Watch
Battery replacement procedure for Casio 901 DW-5600?
hi, if the back plate on the watch the part that is against your wrist has four screws holding the silver back plate onto the actual watch then you need to undo these four screw, once undone you lift the back plate off and then this gives you access to the battery, the screws are small philips (cross head screw) so you will need a small screw driver, their is also a little bracket that holds the battery in place you can either push this over to allow the battery out or undo the small screw that holds this bracket in place this will then allow the battery to fall out,
If their are no screws in the back plate then all you need to do is get a very fine flat head screwdriver and look around the edge of the back plate and you should see a little bit on one of the edges that allows you to put a screwdriver into to allow you to lever the back plate off if it has no screws then its just a push fit so just pry the back off and this will give you access to the battery then like above the battery will be held in place by small bracket undo this then remove the battery.
when fitting the new battery make sure you dont touch the top and bottom of the battery as this will flatten it really quick so just push it in place then refit the bracket then either push the back plate back on or screw it back on depending on the type of back plate once this is done you watch will be working again
Aug 14, 2010 | Casio DW-5600E-1VCT Wrist Watch
Watch
I would recommend you to go to a Juwelry, or a watchmaker and let him put the plate back on it. They might do it for free, or it will cost you 3-5 euros/dollars, nothing much;)
Jun 26, 2009 | Watches
What do you use to snap on the back plate of a wristwatch
Tools are available from many watch suppliers, one is Jules Borel, jborel.com, best to get a new gasket and mabey a spare if you wear this in the water then a new crown or crown seal also.
Jun 11, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
I wish to replace the battery myself, how do I do this?
Polar tells its customers to send watches to them for battery replacement. But the Polar Fitwatch is too old (may have been introduced in 1997?), and they no longer support it. So the only solution is to replace the battery some other way.
For most people I'd say go to a store that sells watches, they'll replace the battery for a fee.
For those who are handy, you can replace it yourself. I did mine yesterday.
The battery is a common type - CR 2032.
You'll need a small screwdriver, philips type, I think. Maybe around 00, or thereabouts. And you need tweezers, preferably with a rubberized grip.
There are four screws holding the back plate. Remove three, and loosen the fourth. Slide the back plate aside.
I unscrewed the screws, then used the tweezers to take them out. They're a bit small for your fingers to get a good grip on them.
The battery is held by a plastic holder that's held by 4 screws. These are (to my eyes) slightly smaller than the ones holding the back plate, so please keep those separate - and keep track of all the screws.
Remove the plastic holder, and make sure you keep track of the spring that's between the holder and the back plate. It'll likely fall out when you turn the holder over.
The holder keeps the battery with a small prong, but it's easy to slide out the battery. Replace the battery, getting the orientation right, making sure you don't touch either side with your bare fingers. This part is easier than it sounds.
Replace the holder, and of course you noted beforehand what the orientation was, so you get it in the same position.
Use the tweezers to drop each screw into its hole, then screw it in.
By this time, the watch will probably start beeping when you tighten one of the screws, because you depress one of the buttons on the front.
Put the spring back in its hole, then slide the backplate back into place, and drop the screws in place with tweezers and tighten one by one.
You should be able to find a manual (which doesn't cover battery replacement procedure) by searching for polar fitwatch manual.
Apr 28, 2009 | Watches
Pulsar battery replacement
Pulsar battery replacement can be found at amazon, here: Rayovac Batteries Lasts as Long Costs Less. Best of luck
Jul 20, 2008 | Pulsar Watches
Watches Logo
19 people viewed this question
Top Longines Watches Experts
michaelrt616
Andrew Taylor
Andrew Taylor
Are you a Longines Watch Expert? Answer questions, earn points and help others
