Question about Oki Electric Industry MC361 AllInOne Laser Printer
Tray mismatch 461 - Oki Electric Industry MC361 AllInOne Laser Printer
What is media mismatch mismatch error
you have the tray programmed to something and are sending the job as something else ex.sending as plain but the trays are set for thick
May 21, 2014 | Kyocera Office Equipment & Supplies
When i try printing with my sharp ar-m205, it automatically reselect bypass tray and gives error "check bypass tray: out of paper or missfeed". But the tray i originally selected is tray 1.
Size mismatch between your print request and the size specifed for the paper in the tray. these trays do not auto-read, you have to tell the copier what size is in the tray
Nov 01, 2013 | Sharp AR-M205 Copier
Feed from tray problem
it will always try to pull from the MP tray if it has a media size or type mismatch even if you default to tray 1. Check your media size and settings
Aug 10, 2013 | Kyocera Office Equipment & Supplies
Display says paper size mismatch.
Check the paper trays, they have a slide movement on them
at the back of the tray their might be some tabs to move for the right positions of the paper size,
Check the reports menu button on the console, make sure the trays say it has the right paper installed for that tray. Each tray has to be told what type of paper it holds.
The machines needs to be configured in the settings menus.
Good luck.
Jul 22, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Paper size mismatch
If the paper supply trays have movable edge guides, make sure the guides are against the paper, also insure the paper is oriented the same a s the print job or copy require.
Hope this is of some help.
Ed
May 06, 2009 | Xerox WorkCentre M20 Black and White...
Size mismatch
First cancel all print jobs from the attached computers. In the control panel you can asign the paper size for each tray. These setting also have to match the computer's settings for this printer. You'll find the information on this printer from the printer;s file under properties.
Jun 03, 2008 | HP LaserJet 4250n Printer
Oki Electric Industry MC361 AllInOne Laser Printer Logo
63 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Tony
Roger Binsfeld
Victorman
Victorman
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
