Question about EuroTech EDC158 Electric Dryer
My Eurotech EDC158 dryer's heating element stays on when cycle is complete. With power switch on and the cycle complete or the cycle selector/timer dial turned to "off", the heating element stays on. Turning the power switch off or opening the door will turn the element off. Is this a problem with the timer, or the control board?
Machine is set to drain out, Drain light stays on
This means that the washer part of the cycle is complete but there is still too much water in the unit. Check the hoses and see if the drain hose is plugged or sitting to high.Check the pump and filter to see if something is lodged in it.
Jan 23, 2014 | EuroTech EDC158 Electric Dryer
Who services eurotech dryers near zip 98368
Clean out your vent before calling a repair man.
Apr 18, 2012 | EuroTech EDC158 Electric Dryer
Have power at outlet nothing happens i dont have wiring diagram am making a leap that it is a fusible link i just went to work at apts that have several of these washer dryer units no owners manuals or...
Never heard of them. However they are all pretty much the same. Everything works in a loop, If it wont do anything probably door switch or start button, or perhaps heat selector switch.. Could be a fusable link coming off of the motor to the start button. There is hi limit switchs close to the heating element, and therostat. Check them for continuity. They only stop the heat tho. There is a Hi cabinent switch at the end of the exaust, after the clothes. If it blows you have to get another. You should be able to do Google Image search for wiring diagram of just about any dryer built like that and go from it. At least get an idea.
Good Luck
May 02, 2011 | EuroTech EDC158 Electric Dryer
My dryer spins but do not heat up...why is that
Main element disconnected or, burnt out. Disconnect cord, remove back panel& check that element is connected at all places. If broken element--you may stretch it a bit & attach both pieces together. Test before putting panel on, but stay clear--keep it away from ANYTHING flammable!
Feb 13, 2011 | EuroTech EDC158 Electric Dryer
My EuroTech dryer turned on for a second then I heard a popping noise and it turned off. I noticed at the bottom of the dryer (right side) looking through the vent, I saw a spark. What is wrong? I do not...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The electric heating element broke and is touching the metal and shorting out...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 13, 2010 | EuroTech EDC158 Electric Dryer
Heating element replaced. Worked one load and back or dryer seemed very hot. Turned off and later ran on low. Next load no heat.
Hi.
There is either a problem with the thermostats that turn off the heating element, or the heating element is plugged (elements has contact to ground and stays always on).
Heating element and thermostats are tested reading Ohms with a multimeter set at Rx1. If the circuit is open (Ohms stay infinite), then the part is defective.
If the machine overheated, then the element may be gone again. Test reading Ohms.
Also replace the thermostats (there should be two or three of them), unless the element had a contact, the most common cause for overheating is a shorted thermostat.
Aug 04, 2010 | EuroTech EDC158 Electric Dryer
Runs but no heat - can't find a Minnesota appliance repair business that supports Eurotech
Could be heating element or thermostat.....Look for a reset red button at back to push in 1st...
Jun 10, 2010 | EuroTech EDC158 Electric Dryer
Need heating element for dryer
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
May 27, 2010 | EuroTech EDC158 Electric Dryer
EuroTech EDC158 Electric Dryer Logo
Top EuroTech Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an EuroTech Dryer Expert? Answer questions, earn points and help others
