How can I make custom-sized impulse sealer bags?
    New Friend:
  • 50 Answers
I found this great video that explains how to do it on You Tube:
http://www.youtube.com/watch?v=zYyP4i62AYw
Posted on Oct 21, 2013
Cannot get it to vacuum.
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
Mar 07, 2016 | FoodSaver Food Saver Vacuum Sealer...
Silicone rubber pad for impulse heat sealer
http://www.pack-secure.com/Auto-Sealers_c_531.html
Dec 04, 2013 | Aie Silicone Rubber Pads For Automatic...
What is an impulse sealer?
An impulse sealer heat-seals objects by sending high current on impulse to a heater ribbon, equipped on the surface of the heat-sealing blade, to generate heat that enables thermal-sealing through thermal conductivity. The section to be sealed is placed between the heat-sealing blades, pressed and thermal-fused when current and heat are delivered on impulse through the heater ribbon. After the current stops the seal remains under pressure to cool and to give it a clean finish.
(Source: The Hoso Times, published by Nippo Co., Ltd.)
Jan 28, 2013 | Office Equipment & Supplies
Vacum works heatseal does not seal can i replace seal
Sealing always tends to be the problem with FoodSaver because during the course of normal wear and tear, the sealing strip and wire will naturally need to be replaced.
You can get replacement heating wires and strips at www.elementandteflon.com
We started out selling just replacement parts for heat impulse sealers but we kept on getting customer requests for FoodSaver parts so we've added that section to our website.
Dec 14, 2010 | Tilia Foodsaver V835 Vacuum Sealer
How do I work a Salton vacuum bag sealer (Model BS-20)? I can not figure out how to get the air out of the bag.
This style of vacuum sealer has to use a special bag with a " dimpled " surface to let the air escape through the pinch jaws of the vacuum sealer.
The folowing web site has bags and rolls that can be cut ro make any size of bag you require. You can buy on line direct from the manufacturer as well as purchase more industrial vacuum packers
http://www.foodmc.co.uk/Category/113-textured-bags-for-external-bag-machines.aspx
Jun 14, 2009 | Vacuums
583 people viewed this question
jasbo
jasbo
