Question about 4-Seasons 2000 Chrysler Voyager Fan Motor
I have to empty the radiator....how? I also have to empty the water out of the heater...where is the heater & how do i do it? (Yes I'm female & never doe this before but I'll give it a go haha) It's a 2000 chrysler voyager SE (don't know about the four seasons stuff??)
    New Friend:
  • 3 Answers
Usually there is a drain plug on the bottom left or right of the radiator visible looking from underneath the front bumper ,if there is none visible than with engine cold remove the front lower radiator hose and let it drain and most likely drain the fluid in the heater core also
Posted on Oct 21, 2013
    New Friend:
  • 4 Answers
There is usually a drain plug located at the bottom the radiator. Remove it and the antifreeze will start pouring out. Make sure you have at least a 5 gallon bucket under the plug to catch the fluids. as for the water heater it will drain through the radiator. Good luck.
  • Kelly Tumbers
    Kelly Tumbers Oct 21, 2013
    I will give it a go...thank you!
How do you drain a water heater?
there are several ways of doing this dependent on type of water heater. firstly turn the feed / supply off, turn off the power supply below the heater there could well be a drain / blow off this empties the water out of the heater, alternatively if the water heater supplies radiators you need to drain these down also to do this one should have a drain on the pipe work, if not you can get a clip on version which is easily installed.the other way of draining this water heater is to go on the manufacturers web site and get the installation manual. hope this helps
Oct 25, 2013 | Water Heaters
I have to empty the radiator...how? I also have to empty the water from the heater...where is that & how do I do it? (yes, I'm a girl...first time ive done this haha)
then I suggest you purchase a repair manual for your make year and model car so you can read and refer to it as you under take the task at hand
Oct 21, 2013 | 4-Seasons 2000 Chrysler Voyager Fan Motor
1996LINCOLN MACH III LOW COOLANT MESSAGE AND OVER HEAT x2
Sounds like sticking thermostat. Replace thermostat if you see no leaks anywhere else.
You need to drain out any bad coolant or water when you replace thermostat and refill with concentrated antifreeze until you have at least 50% antifreeze water ratio.
You have to bleed the engine with new antifreeze solution so there's no air. I always go to youtube and see how mechanics do each engine bleed. Search your car and engine and `coolant flush'. don-ohio
Mar 11, 2017 | 1996 Lincoln Mark VIII
Yes it is normal just no hot air
1. When setting the temperature to MAX, blower level to FULL and outside air Vent CLOSED, no hot air comes out after 2-5 minutes?
If YES, when did you last flushed your radiator and is it full?
2. if more than 5 years ago, flush radiator system, instructions are usually in Owners manual. Use a bottle of Radiator cleaner, run egine hot for about 10-15 minutes, carefully open petcock in bottom of radiator to flush out radiator, WARNING, careful as flushed coolant would be boiling hot. As sson petcock is open and water start to flow out, carefully open radiator cap to enhance flushing flow. Use garden hose to fill radiator while flushing until water coming out from petcock is cold and clear.
Once clear, start engine, turn heter full and blower full blast and keep hose in radiator flowing full, leave petcock open until clear water flows out again. Once clear waters comes out, turn off engine,turn off garden hose and let water drain empty radiator. Once it stops flowing out, close petcock snug and put radiator cap on, pull off radiator coolant catch bottle, clean bottle for any debris and dirt. Drain any water, leave bottle empty and put it back onto its place.
3. Fill radiator with 1 gallon (4L) of concentrated coolant, top up radiator until full, fill catch bottle with concentrated coolant, start engine and keep it overflowing until no bubbles comes out and the radiator is fully hot. Once it is flowing good, close and connect everything. Drive with it and keep catch bottle filled as necessarry.
Good luck. Give as vote and good comment if this advise solve youor problem. Thank you.
Jan 05, 2011 | 2000 Chevrolet Suburban
I'm flushing my radiator in ford e-350 v8 with 5.4l......has strait water in it now......when i flush I'm trying to figure out where the heater return hose isto flush the core or do I even need to...
when i flush my radiator.i would first drain out all my old antifreeze.fill radiator up with water then put a bottle radiator flush. pour in radiator.then i will crank car up turn on heater wide open allowing radiator flush flush out radiaator and heater core when done i will drain out water. put in more water flush out all radiator flush out engine and radiator.then put back in antifreeze.you dont want to run water hose to heater core it will rupture it water pressure too high.
Dec 08, 2009 | Water Heaters
Losing water gradually and condensation inside window. heater matrix?
Yes, this is a sign that the heater radiator leaks.
Try to solve with a radiator leak stopper for ease. If that doesn't work you have to dismount the heater and replace the radiator.
CAUTION: Coolant vapours are HARMFULL/POISONOUS
Nov 01, 2009 | 1996 BMW 318
When you bypass the heater core the path for the water to go through the core is gone. Correct?, you have connected to engine water line out to the engine water input? thus bypassing the heater core........
No, you just won't have water flow through the heater core, Coolant flows through the engine through the lower radiator hose as the water pump sucks it out of the radiator and pushes it through the engine. It then flows out the top radiator hose when the thermostat opens. It then flows into the radiator to cool off.
Is your heater core leaking?
Aug 27, 2009 | Ford Expedition Cars & Trucks
Water Leakage and Smell of Coolant when driving and Using Heater
For a car this old It's almost certainly the water pump. You may also look at the rubber water hoses also since they do not last forever either. Do not drive without fluid in the radiator - it will warp the engine header and the engine can seize up.
Mar 19, 2009 | 1996 Toyota Tercel
96 suzuki vitara - radiator empties but no visible leak
Check the passanger side floor board for moisture this could indicate a bad heater core. Then I would check the engine oil and make sure its not milky looking (head gasket). make sure when you fill it let it run with the cap open with you looking into the cap to be sure is circulating and not vapor locked (air pocket)
hope this helps
Feb 01, 2009 | 1999 Suzuki Vitara
4-Seasons 2000 Chrysler Voyager Fan Motor Logo
91 people viewed this question
Top 4-Seasons Computers & Internet Experts
Todd Arndt
Todd Arndt
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a 4-Seasons Computer and Internet Expert? Answer questions, earn points and help others
