Question about Magellan RoadMate 3000T GPS Receiver
Locked up password
I can't get the unit unlocked in order to get to the main menu is their a code to unlock it from the key pad
  • expo9797 Dec 05, 2007
    when i power up my magellan roadmate 3000t, the startup screen the say magellan stay on the screen and and nothing else happens, the screen stay blue with magellan showing on it.
  • mjcMedic Dec 27, 2007
    When I power up, the unit cycles itself then goes to a generic user warning. After hitting "OK" it goes right to the screen asking for a password. How do I get past this so I can use the unit. Is there a master password or secret ninja technique? Please help.
Dosent work
Posted on Feb 12, 2008
Let the battery die, plug in for a second, continue to hit escape unil you can see first menu options screen, quickly try to hit a option before the password screen comes back. it will take several times. once you have broken through to the first menu screen hit ++--+- (volume menu) secret menu come up then select reset device to factory
BEFORE - HIDDEN MENU - AFTER
following : ++--+- (volume keys)
Posted on Dec 18, 2007
Password for jvc tv v-chip
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Jan 17, 2013 | Televison & Video
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
How to turn off child lock without remote control jvc lt-32sh6
OR
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger.
Nov 01, 2012 | Televison & Video
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
[2]
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
My keypad is locked.please help me
ky keypad is locked by security code what can i do 4 unlock 2730c
Aug 12, 2010 | Nokia 2730 Cell Phone
MY IPHONE IS LOCKED HOW CAN I UNLOCK IT.WHILE IAM COPYING ITUNES TO MY PHONE IT IS LOCKED.ON SCREEN IAM GETTING ONLY THE EMERGENCY CALL KEY PAD AND NOTHING IS THERE.IAM NOT ABLE TO OPEN THE MAIN MENU
Dec 26, 2009 | Apple iPhone 3G
FORMAT CODE FOR MOTOROLA L6
my motorola l6 is keep on restarting when ever i press a key so i thought it might get better to reformat my phone so i need the format code for it.
Mar 23, 2009 | Motorola Mobility L6 Cellular Phone
Motorola razor v3
  1. From the main screen, press the Menu key.
  2. Select Settings.
  3. Select Security.
  4. Select New Passwords.
  5. Select Unlock Code and press Change.
  6. Enter the default unlock code and select OK.
    • The default code is 1234.
  7. Enter the new unlock code and select OK.
  8. Enter the new code again to verify and select OK.
  9. Press the red End key to exit.
Dec 09, 2008 | Motorola Mobility RAZR V3
Motorola L7
There are two codes for the security of the MOTOROLA L6, the unlock code which is usually 4 digits and is set originally to '1234' and the security code which is 6 digits and set at the factory to '000000'. These codes are the same across the world unless a specific service provider decides to change them.
• To change the unlock code, you can go to NEW PASSWORDS by going to the SECURITY option in the SETTINGS menu. The phone will prompt you to enter UNLOCK code, Put in '1234' or the last 4 digits of your phone number and if both don't work, try the security code 6 digit number.
• If you lose the other codes like SIM PIN code, PIN2 code, cell barring password and even the SECURITY CODE, these can be reset by only the service provider.
• You can prevent others from misusing your phone locking it when not in use. This is achieved by selecting LOCK NOW in the PHONE LOCK options in the SECURITY menu
• Choosing AUTOMATIC LOCK to ON in the PHONE LOCK menu will lock the phone automatically whenever it is turned off.
• A locked phone can receive phone calls but will need to be unlocked using the code to be answered
• There is also a simple way to prevent accidental pressing of keys by locking the key pad using the main menu soft key followed by the '*' key in quick succession.
Nov 17, 2007 | Motorola Mobility L6 Cellular Phone
Magellan RoadMate 3000T GPS Receiver Logo
246 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
