Question about Konica Minolta Bizhub C220 Color Copier/Printer/Scanner
I have a machine that has a white streak down the centre of the page on cyan ...I have replaced drum and dev units ,transfer belt, print head unit ,toner and H.V unit. I still have the white streak down the middle of the page when doing half tones in test mode. can some please help me...
  • Clement Williams
    Clement Williams Oct 21, 2013
    Please note that this has nothing to do with scanning...I am a engineer from Konica Minolta.
    New Friend:
  • 4 Answers
Need to clean your scanner glass
Posted on Oct 21, 2013
Testimonial: "I have colour change when printing as the printer does not add cyan down the middle of the page...so blues would turn out orange."
Vertical white skreaks when printing
Check the remaining service life of the drums, also check the condition of your transfer belt. It is most likely your problem is one of those two elements.
Oct 07, 2014 | Lexmark C543DN Laser Printer
C252 streaks
Check your consumables. Press utility then check consumables. If anything is at the end of life, it needs replaced. It sounds like your drums are not cleaning properly and need to be changed. If they are fairly new, then I would suspect the transfer belt. If you know hoe to get into service mode you can go into test mode. Then run your halftones on each color. If it moves around, its your drums. If it stays in one spot, its your transfer belt. Also you could check your drum units. If they have streaks going across the green drum, like its dirty, then its coming from the drums.
Apr 17, 2014 | Konica Minolta bizhub C450P Laser Printer
Ricoh Aficio 3800C: How do you clean the Development Unit Hello, I have a Ricoh Aficio 3800C. I noticed that there are faint Cyan streaks when I print. I opened up the printer/copier unit and looked at...
I believe what you are referring to is the drum inside the toner cartridge. The drums are usually very strong colors, blue or green and if it is streaking then the drum cleaning blade has failed on the inside and you need to replace the cartridge.
Feb 14, 2011 | Ricoh Aficio AP3800C Laser Printer
What does code: DK means?. How can I fix it?
This code indicates that the Black Drum has reached 100k. It could also be the black developer and primary transfer belt are at 100k.
DC = Drum Cyan
DM = Drum Magenta
DY = D
rum Yellow
DK = Drum blacK
Even if it is reset you will still need the drum unit or drum/mc kit replaced very soon. These units do not last much longer than specified. After this the print quality deteriorates rapidly. Eventually the drum edges wear away so much that they can force developer out of the dev tank. You can usually get away with not replacing the K dev. If you reset the K dev at the same time as replacing the K drum unit, the machine adjusts itself can function normally. A dev normally lasts 200-300K. The primary belt unit lasts longer than the 100K spec and often beyond 200K out of them before replacement or refurbishment.
Finally, make sure that the Firmware is up to date.
Sep 30, 2009 | Sharp MX-3501N All-In-One Printer
2530 DL problem printing, has a streak of white line all the way down the page. Has plenty of toner in it.
If all the toners are not empty, then you have toner or dust on the print head unit. Remove the drum cartridge and you will see beneath it a narrow glass, just be sure that glass is clean.
Jun 07, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Copystar cd-2550 copier , drum replacment print problems
hi
the drum unit on this model has two plugs which need to be plugged in and one on the dev unit that can come loose.
also the metal mechanism under the dev unit has to be pushed in to enable toner to get onto the drum.
is the transfer roller fitted correctly?
Mar 26, 2009 | Kyocera Copystar CS-1820 Black and White...
Ricoh Aficio CL3500N is now printing all documents with lines/streaks all down the left margin of the page. What do I clean or replace to get rid of these unsightly lines printing on every page?
you can try printing a page in black only, then one page each in the 3 other SINGLE colors: Cyan, Magenta, and Yellow. this will eliminate/ confirm one of these causing problem.
the replacement of Transfer Belt Cleaner or Cleaner Assembly is another to try after the above separate-color thing. see if there's a status page of life remaining on replaceable items, including the Transfer belt assy.
i'll assume you didn't scan the job- - this isn't a multifunction scanner/printer type machine?
ok, next in line is to check the Fuser unit, the part on the upper left side/top of printer. if the same streaks appear on the Main fuser rollers, these fuser units cost about 350 bucks. there is also a Fuser Kit, which costs much less, but its job is to add Fuser Oil to the fuser unit and keep paper and ink from sticking.
a guy could suffer sticker shock from the costs of running one of these, considering you could drop a grand buying all 4 drum units, a fuser unit, and a transfer belt assy. . . .
Feb 16, 2009 | Ricoh Office Equipment & Supplies
Yellow not printing - but only in streaks
Your yellow problem sounds like a bad yellow developer housing. Take the drum out and look at the developer housing, You will need a flash light to do so. See if the roller is solid yellow. Even if it is there may not be any developer left in the housing.
The Cyan sounds like the drum since it gets worse as it prints.
That can also be caused by the transfer belt cleaner. But that normally is the opposite. It has a rainbow sort of streak and it gets better as the machine runs.
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
White Lines
My magicolor 2430 dl prints fine until i print a photo then it leaves vertical streaks down the page, how do I correct this and if its dirty how do i clean it.
jim
Jan 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Konica Minolta Bizhub C220 Color Copier/Printer/Scanner Logo
90 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
