Question about Garden
Part list Karcher T21/1 - Garden
The discharge pressure on my Karcher electric pressure cleaner varies. When low no cleaning can take place. How can I fix?
Karcher 2 26M Parts List and Diagram 16016020 eReplacementParts com
There are videos on the site that show how to troubleshoot this. The issue is most likely a valve that is sticking open sometimes.
Mar 05, 2018 | Karcher Garden
How do i take out a broken spill valve
Go online to Karcher or a big Karcher agent, stick in your model and download a parts list. This will likely show you whether it comes apart and also the part number if you want a new one.
Jul 21, 2014 | Karcher Garden
Operating Manuals Karcher 302 presser washer
do you want a "how to use the machine" or "parts diagrams" or "how to repair" ?
"how to use" is the same for all pressure washers...........
i guess you own a KB 302 1.994-923.0 but karcher dont list this "operators manual"
this is for the k 370 :
http://www.sparesgiant.com/media/import/karcher/k370%20op%20man.pdf
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Jul 12, 2013 | Garden
I would like the instruction book for the Karcher k2-59 pressure washer
The manual is available on the Karcher website here:
http://www.karcher.co.uk/uk/Products/Home__Garden/Pressure_washers/Entry_class/16724110.htm
Click on product manuals and then pick the fourth file in the list.
Mar 21, 2011 | Microwave Ovens
My Karcher 2.99 starts and stops, (pulses) when th...
Is liquid leaking from the base, when the Pressure washer is on ?
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 21, 2010 | Karcher K2.26MR Electric Pressure Washer
My Karcher pulses when on standby,stops when i use the trigger,but it also seems to have lost pressure.Is less than 6 months old but have lost receipt!
Is there a leak from the bottom ?
If so Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A design weakness.. A New Manifold Complete Replacement approx. $61.03.
If not you may replace the Pump Manifold Housing from Karcher, or locate a local Karcher Service Center.
If under 1 year old, and you can find a receipt,Karcher will replace the entire Pressure Washer under warranty.
May 03, 2010 | Karcher K 5.85 M Electric Pressure Washer
Karcher K 3.86 electric. Was working fine and
It sounds like you have cracked part inside. Parts availability depends on were you live???
Sep 18, 2009 | Karcher K 2.25 R Electric Pressure Washer
Karcher k4.98 switching on and off
The machine has a pressure leak. Check for a cracked controll head or either a leaking outlet elbow. The machine will short cycle if the holding pressure can not be maintained
Feb 19, 2009 | Karcher K2.26 Electric Power Washer
LOST KARCHER INSTRUCTION BOOK, ARE INSTRUCTIONS ON LINE
Here is the offical link to manuals and warranty cards for the residential models of Karcher Pressure Washers
http://www.karcherresidential.com/us/Service/usermanuals.htm
Jan 22, 2009 | Karcher K2.26 Electric Power Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
