Question about Cycling
How to adjust Shimano ST ef40 7R - Cycling
3 Suggested Answers
miller129480
  • 16 Answers
SOURCE: How to adjust shimano acera x ST-M290 shift
Take the allen bolt out take it apart if nothing is broken it will a need cleaning.A spray solvent and work the springs up and down no oil should be a quick fix.
Posted on Oct 12, 2009
  • 4 Answers
SOURCE: ST EF20 SHIMANO right
Remove the top plastic cover secured by two small screws
-At first glance you'll only notice half of the gears teeth, and as you shift the lever it will apear that the lever's push will bottom out and will not shift past the 4th or 5th gear.
- If you look close with a light you will see that teeth run completely along the entire gear and the teeth get super small just before the biggest tooth of the gear.
-the problem is that the shifter's cam (hooked lever) aka engager is seized and cannot swing into and bite into the smaller teeth.
-With some lube or even wd-40 spray the engager and exercise it with a small screwdriver so it can loosen up and spring into the small teeth.
-Start shifting and releasing several times to work the the lube in
- Install the cover and you're done!
Posted on Nov 03, 2011
Exploded view of shimano gear shifter altus st-ct90
Sorry, Shimano never intended those shifters to be taken apart and serviced, so they didn't release an exploded view. Here's a link to the orginial EV document. http://bernd.sluka.de/Fahrrad/Shimano/TM/ST-CT90_1995.gif
Mar 30, 2017 | Shimano Cycling
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
I am using a new shimano 6603 SL braze on derailluer with a fairly new, but in good shape shimano 6603-G crankset, but an older 6510 triple shifter, all with a 9 speed chain. Shifting onto the middle and...
It is hard to tell via the Internet. I suggest that you take it to a bike shop. They will get it shifting smooth, and, if not tell you what is wrong.
Jul 22, 2011 | Shimano Ultegra ST-6603
I need instructions on how to use Shimano Sora STI 9 speed 27 gears total)(integrated with brake levers)
http://techdocs.shimano.com/techdocs/blevel.jsp
Key SORA into the FIND field.
About 5th up from the bottom are the tech docs for ST-3303 levers. Download them both.
Shifting in general...
Google "how to shift a road bike". Many videos.
Good real world advice...
http://www.sheldonbrown.com/gears.html
Find good information on various adjustments here...
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
May 08, 2011 | Cycling
Is there are barrel adjustment screw that goes into the shifter/lever on my Shimano 105 ST-5600 STI lever? The cable feels loose and other bikes (that I see) have an adjustment barrel screw. If not,...
Barrel adjusters on road bikes are usually where the cable enters the cable stop at the top of the down tube. They're for ON-THE-FLY adjustment trimming, not overall adjustment.
You need a basic adjustment...
Apr 13, 2011 | Shimano 105 ST-5600
Need advice for Shimano ST-7900 nameplate replacement
Don't know if you have an exploded view diagram of the levers . If not you can download from http://techdocs.shimano.com/techdocs/index.jsp
In the road bike drop down list select Dura-Ace, go down to ST-7900 and select document EV-ST-7900-2874. I don't advise you to take mech apart unless you have special tools and bags of experience handling complex mechs. However you will see that name plates are held by single screw which should be no problem.
Nov 19, 2009 | Shimano Cycling
Shimano st 7900 shifter,left lever apart and how to reassemble
You can download an exploded diagram of the 7900 series STI shifters here:
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-7900-2874E_v1_m56577569830670749.pdf
You can reassemble them according to this diagram.
May 11, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
Cycling Logo
253 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
