Question about Miele Dryers
Miele tumble dryer novotronic T 277 C - when i turn it on and try to start a program nothing happens...
  • 163 Answers
SOURCE: Miele Dryer heater bank
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
rogrrabbit
  • 986 Answers
SOURCE: Miele Tumble dryer will not produce heat .
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Oct 15, 2009
heatman101
  • 43501 Answers
SOURCE: miele novotronic T640 about 9/10
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
  • 177 Answers
SOURCE: where is the reset button for the miele t200
there is no reset button for this unit. if it is not heating you may have blown your thermostat
Posted on Sep 05, 2010
  • 2468 Answers
SOURCE: Miele Novotronic T230C Electric Dryer Dryer is
first check for 240 volts input on the unit if its electrically heated if you have no heat at all,then if you have some heat but it cycles on and off heat wise and the heat isn't as high as it should be,it can be the high-limit thermostat,the cycling thermostat both on the element housing,or it can also be a thermistor sensor on the blower housing if it only acts up on certain settings,you can bypass the 2 components on the element by jumping the wires on the components carefully together temporarily to see if this helps the heating cycle,but not the thermistor,as this is a resistance sensor
Posted on Oct 05, 2010
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
How do you change a belt on a Miele Novotronic t220 tumble dryer.
You might want to post this in the dryer section. Have you checked youtube?
Nov 03, 2013 | Miele Novotronic T220 Electric Dryer
Miele t224 tumble dryer is broken. the problem is how to access the drive motor and drum
http://www.maybenow.com/how-to-remove-the-front-panel-on-miele-dryer-q24016479
Mar 06, 2011 | Miele Novotronic T220 Electric Dryer
Miele novotronic T640 about 9/10 yrs old tumble dryer keeps stoping and the start button flashes when it stops
heatman101
Aug 26, 2010 | Miele Dryers
Where is the reset button for the miele t200 novotronic special tumble dryer please
Oct 30, 2009 | Miele Novotronic T1570C Electric Dryer
Holes in clothes
I'd bet the holes are the same size as the holes in the dryer tumbler. the only thing I can think of is that your dryer isn't tumbling and the heat that is pushed through the holes is burning your clothes.
Apr 18, 2009 | Miele Novotronic Premier 500 Front Load...
The on switch will not turn dryer on
Hi everyone. I would be grateful for any help. I have a Miele Novotronic T220 tumble dryer. I cannot switch the thing on! The finish lamp is lit continually, and I cannot start another drying cycle.
I have unplugged the machine and pressed the start button again, but nothing happens.
Has anyone got any ideas for a technophobe.
Aug 10, 2008 | Dryers
Dryers Logo
192 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
