Question about Freezers
C250t kelvinator thermostat
Kelvinator opal upright freezer is over freezing..is there a temperature control somewhere or what could be the problem?
the problem could be the heater element, bimetal, thermostat, fuse.must open freezer cover and check.
Nov 14, 2016 | Kelvinator Freezers
Where is the defrost thermostat located on kelvinator freezer
Depending on the model you pull the cover from evap coil and you will see either a bimetal thermostat or the timer
Jun 30, 2015 | Kelvinator Freezers
Kelvinator freezer model kfu09m2aw2 won't get cold. could thermostat be bad
Yes it is. Just rotate it clock wise and vice versa and see it will work in case No then check the gas
Sep 25, 2014 | Kelvinator Freezers
Freezer serial # 845440256 age?
Replacement thermostats depends on whether the fridge is a double door or single door model. You can buy this part from your appliance parts store/supplier.
Feb 20, 2014 | Kelvinator Freezers
I have a two door kelvinator it freezes the food aside
Ok, your thermostat is buggered, the fridge wont turn off becaust it hasnt been told from the thermostat, easy DIY but be aware DISCONNECT the power first and unplug from the wall and do not kink the thermo tube when replacing. Buy the same thermostat and take a pic of where the wires go before removing the old one. Hope that helps, if you need help, call me on 08 9523 0552 Russ and I can help further.
DONT FORGET TO VOTE, I JUST HELPED YOU FOR FREE
Mar 02, 2011 | Kelvinator Freezers
My Kelvinator refrigerator temperature varies a lot; thermostat problem?
check to see that the door closes tight and it is not losing cold air. If it seems to be ok I would check the thermostat
Oct 07, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator Fridge/Freezer C 340 RM does not switch off
the problem is your thermostat in your frig.the dial with numbers on it.it is no longer sensing properly and theres nothing you can do but replace.that is as long as your dial is not broken[the plastic pice with the numbers] God bless ,tom
Jan 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezers Logo
18 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
