Do not put mic switch it line input the mic has a preamp that will amplify microphone ss they have very low output, by using line the tascam will take a higher levl, why would you want to go mixer to mixer?
It is much easier to use an analog mixer and microphone thru the mixer. I would plug the microphone into the mike input on the mixer and then the Karaoke machine to stereo LINE inputs on the the Mixer, then Mixer Output or Tape Output on the mixer to analog LINE IN on the MiniDisc recorder.
Let me know if you need more info.
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
I guess this is what you need View Tascam 2488 PDF User Manual Online
If you have any question about your home appliances you can always check manualbirds.com for free manuals and guides.
If you only want a manual, Teac/Tascam in Montebello, CA. If you need help with it, please visit my website at audioserviceclinic.com. You may contact me through the website. Thank you.
http://www.manualnguide.com/download/manual-guide/tascam-dm-24-digital-mixer-automation-manual.html setup information in manual above-i think cable will be found in a music equipment store near you.
