Question about Acer Aspire One PC Notebook
I have a acer mini laptop aspire one d270 with windows 7 starter.I have just now discovered that my laptop is not starting.It is showing me two options: 1)launch startup repair(recommended) 2) start windows normally But startup repair cannot repair my problem. What do I do?
    Problem Solver:
  • 12 Answers
You always want to start your windows normally.
In my 10 years as a computer technician I have learned that you never use the startup repair option cause it will never help.
Any more questions or concerns feel free to contact me Country Tech Repairs
Posted on Jan 21, 2015
legna
  • 53 Answers
SOURCE: Acer Aspire 3693WMLi -Launch startup repair
It might also means that your hard drive is not working properly. My laptop's hard drive went out making the same blipping sound and white screen after that, this happens some times for over heating. Now if you get a error number let us know it might help
Posted on Aug 30, 2007
pagebor
  • 2785 Answers
SOURCE: Acer 3680 will not boot up.
try to boot in safe mode, if you can then from there try to remove the latest software or hardware you install.
if you are unable to boot in safe mode, then try to repair or reinstall the os.
plz post your findings
Posted on Jun 06, 2008
Alcatrazx
  • 65 Answers
SOURCE: Windows failed to start !...
Hello
You seem to know a bit about computer so I will give you a good detailed solution which might be of help. READ CAREFULLY
ASSUMPTION:
I guess that the main issue here is that your hard drive might be corrupted. I am also afraid that you might have erased or repartitioned your computer on a previous occasion if the recovery is not working. Please not that the Acer 5920 you mentioned has an automated system recovery system saved on to your hard drive. Did you by any chance Reformat the whole thing when you got the laptop? Because if thats the case and you removed the EISA partitions there is NO WAY you are going to get the recovery to work.
SOLUTION 1: USING RECOVERY CD's or DVD's
If you backed your system up when you first bought it and you created the CD's DVD's boot from them and recover the system that way. I am afraid that these will erase your C drive and will restore it to the original state when it was at time of backup. BEFORE all this you need to recover any data? In that case do the following:
1. remove the hard drive if you have important data.
2. Put it in a hard drive enclosure (which plugs in USB) and hook it up to another computer XP or VISTA doesn't matter both should work fine.
3. Then backup the folders you would like to make a copy of onto the hard drive of the other computer.
4. Then connect it back to the laptop (obviously make sure that when you remove and plug in this hard drive the laptop is off). And perform the recovery.
SOLUTION 2: If still all the above doesn't work.
If you do not need to backup anything there is no need to do the first 3 steps but you will need another computer
1. Do steps 1 to 3 above to make sure that you backup everything at least
2. Go to my computer on this to which you connected the drive computer Format the hard drive of the laptop (Making sure that before this step you backed up all the important data because you will lose it!)
3. Perform full format (this will take a while) and format it as NTFS, while formatting see if you can hear any funny noises. It could be a good sign that the hard drive is out. During format you should almost hear nothing. if you hear a repeated CLICK CLICK CLICK CLICK CLICK type of noise. Get another hard drive and repeat the above 3 wsteps
4. Get hold of an XP or VISTA installation disk according to what you had on laptop
5. Go to acer website and download all the drivers for the laptop you have and burn them on CD. If you already have a driver disc of the laptop you can skip this step but make sure that you have everything you need on it
6. put hard drive back in Acer 5920
7. Boot from the installation disk XP or VISTA. HINT KEEP the SAME OS if you had XP install XP ... if you had VISTA install VISTA
8. When it asks for serial number look underneath the laptop and key in the serial number from the fancy label you have underneat. It should be a 20 numbers and letters separated by (e.g. xxxxx-xxxxx-xxxxx-xxxxx-xxxxx)
9. Follow instructions and perform a full install
10. Now install all the drivers you have on that disk. These are like small programs. Install one after the other until you install them all. Reboot when asked to reboot... Do not choose reboot later!
11. Phew by now you should have a laptop working again. Isntall office antivirus and antispyware software and GET BACK the data from the other machine.....
CHEERS
Posted on Jan 07, 2009
SLitWrists
  • 35 Answers
SOURCE: acer lapt top will not start in any mode.It says
Hi
Sounds Like Youre O/s is the problem.
If you have youre O/s disk try and do a windows repair form the disk
Kind regards
SlitWrists
Posted on Apr 24, 2009
  • 63 Answers
SOURCE: my laptop wont boot up completely comes up to a
I would enter in BIOS and disable the option to power off after failure. Then start normally and go to “blue screen of dead”. The point of it is a code (four parts, every part contains number and letters). On Microsoft.com search every part and get the explanation. Most likely it is a hardware problem.
Posted on Sep 06, 2009
Acer aspire one d270 netbook how do i go in safe
Start tapping F8 before the windows 7 Splash screen goes away, that should give you access to Safe Mode.
Oct 11, 2014 | Computers & Internet
Can not change my wallpapers in aspire one D270
Be sure which Operating System does It have installed. If It is Windows 7 Starter edition, you won't be able to change wallpapers.
Oct 20, 2013 | Acer Aspire Computers & Internet
Language change english
Go to control panel - choose languages and then modify
May 11, 2013 | Acer Aspire One D270 10.1 Inch Netbook...
My acer aspire one d270 webcam stopped working.When I checked the device manger,there was no problem with the camera.What's wrong?
Its look like you have disable the camera by clicking on the special button. Click on function button on the keyboard then click on all the f keyboard button you will find out the problem .
for better clarification give me the complete details of the laptop , the model and serial no its under the laptop on the square white or silver sticker or on under the battery hood,
Nov 15, 2012 | Acer Computers & Internet
Acer one d270-1824 sound problem
You have issues with your audio drivers, reinstall them and everything will be okay.
Oct 23, 2012 | Acer Aspire One D270-1824 Aod270-26dkk
How to reset an Aspire One D270-1824 laptop
is your window genuine? from the photo, i assumed u had a window 7 genuine...
Jun 14, 2012 | Acer Aspire One D270-1824 Aod270-26dkk
My acer aspire one d270 is not responding.It is just displaying the window 7 starter screen with the acer icon,even the pointer is not moving
reboot your system, after reboot press f8 on the keyboard and highlighted options will appear choose load good known configuration that worked... and its done.
May 01, 2012 | Acer Computers & Internet
Acer Aspire One  PC Notebook Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
