My compaq presario desc top wont load recovery it keeps saying missing files insert disk dont have a disk and f10 isnt working
    New Friend:
  • 4 Answers
Try f2 on reboot
Posted on Oct 21, 2013
4 Suggested Answers
rtrahan
  • 741 Answers
SOURCE: acer 5520 notebook startup issues
You are missing the file NTLDR.exe and NTKRNL.exe. NTLDR is the first file your computer sees when it is booting up and it brings up other files to get your computer started then it turns it over to Windows file called NTKTRNL which actually brings up the Windows operating system. The only wayto fix is to find a Windows disc and copy them over to three folders that you have either win32, windows or winnt. Copy to all three if you see all three buy only one of those starts your system and it seems like it's win32 based on your error, folder under your C: drive. That will solve your problem and your computer will boot up normally.
Posted on Dec 23, 2008
  • 52 Answers
SOURCE: if a compaq presario cq50 says error 1005, what does that mean?
Error 1005 is an HP restore error which means you need to install from a standard DVD from HP. You can order this from various websites on the internet. They are about $30-$45 plus shipping.
Posted on Aug 07, 2009
  • 252 Answers
SOURCE: boot manager is missing and wont load windows 7
If your using a DVD to install the operating system, it could be either dirty (just needs a wipe) or the files on the disk are corrupt.
If you are getting this error while Windows 7 is starting up perhaps you can try doing a "repair". Boot off the DVD do a repair (not from the recovery console) and see if this helps.
Hope this helps.
Posted on Nov 09, 2009
Need to do a factory reset on a presario cq58n and it wont let me
Step 1:
There are multiple instances when you would want to wipe your PC's memory clean and reset it to the factory defaults. Called "formatting," it is often the last-ditch effort to restore a PC to functionality. You will also have to format your PC if it gets crippled by viruses. Although these instructions are for the Compaq Presario, the steps are essentially the same for all Windows-based PCs. Be sure that you want to delete everything--this process is irreversible.
Back up any data that you want to keep by saving it to removable media, such as external hard drives, flash drives, DVD-R, etc. Unplug all peripheral devices, except for the keyboard and mouse. Turn on the computer. As the computer is starting, repeatedly press F1 to initiate the recovery process. When the BIOS setup screen appears, press the right arrow key to select "Boot". Press the down arrow key to select "Boot Device Priority" and press "Enter". Press the down arrow key to select "CD-ROM" and press "+" to move it to the top of the list. Open the CD-ROM tray, and insert the system recovery disk. Exit the BIOS setup by pressing "F10". Be sure to select "Save Changes and Exit". System recovery should initiate. If it does not, and the PC loads Windows, then you have either failed to set the CD-ROM at the top of the boot priority list or you exited the BIOS setup without saving. Press "R" to begin the recovery process. When prompted, select "Full System Recovery". Restart the computer when the process has completed.
Mar 09, 2013 | Compaq Computers & Internet
My desktop compaq presario s4300nx starts up , i can accses set up with f1 but cant start recovery with F10 however the F10 button works in setup, no good to me, ...i have recovery disks the pc just...
you will need a Windows boot disk / Windows install disk / WinXP disk to reboot the PC and install / or repair your OS
rescue disk will not boot your PC
to enable that you need to enter the BIOS, press F1, F2 or Del to enter BIOS , then you need to look for the BOOT seq in BIOS, change that to CD DVD drive as the 1st boot device, Save and Exit and insert the boot CD and restart
this should give you the solution
Dec 16, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
My compaq presario cq60 is having problems loading, once it said a fatal exception error, but that has not been repeated since i used the recovery aspect. but it will not start unless i use recovery all...
it is software issue, ur registry files look like corrupted run registry cleaner reg in out to solve this and do the following Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files.
Sep 17, 2010 | Compaq Presario CQ60-212US Notebook
Hello i have a compaq presario 5000 when i turn
This is a compicated problem. First when it boots enter setup by pressing the F10. Once you are in set up reset all settings to default. Save changes and exit CMOS. If that does not help the situation have someone make you a boot disk, reenter setup and put the floppy as the first boot drive and then CDrom. Insert the boot disk, follow the instructions to boot. Once you are up and running try to roll back the computer to the last recovery point that worked. If that does not work you may need to see a local repair tech.
Feb 04, 2010 | Compaq Presario 5000 PC Desktop
Boot manager is missing and wont load windows 7 on compaq presario c700, no matter what i do it keeps returning to the boot manager missing press ctl alt dlt.screen how do i fix it
Hope this helps.
Nov 08, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario C300 Recoivery Disc 2 corrupt
Hi John.
F11 process is not working and you get a NTLDR missing when you turnon the notebook.
Steps to be performed:
1. Perform hard drive self test from BIOS.
2. If it is passed then use retail version of operating system disk to install XP or try using new recovery disks which nay cost you $15.00.
In your notebook model this issue appears if there is any issue with the hard drive.
Jul 04, 2009 | HP 435768-001 - Compaq Presario C300...
The monitor reads: system boot failure. Insert recovery disk.
McAffee Security or adding memory cards should not effect the ability to do a system recovery, but so be it. Here is a list of presario laptops, do you know which is yours?
s.gif s.gif s.gif » Compaq Presario 12XL325 Notebook PC
s.gif s.gif s.gif s.gif s.gif s.gif » Compaq Presario CQ20-325TU Notebook PC
s.gif s.gif s.gif s.gif s.gif s.gif » Compaq Presario CQ45-325TX Notebook PC
s.gif s.gif s.gif s.gif s.gif s.gif » Compaq Presario CQ40-325AX Notebook PC
» Compaq Presario CQ40-325LA Notebook PC
» Compaq Presario CQ40-325TU Notebook PC
If so, click on it and you will find the recovery disks.
Mar 18, 2009 | Microsoft Compaq Presario C501nr Notebook
Laptop wont turn on properly
A vital component that windows requires to run is corrupted. To fix it, you need the OS disc
In Windows Vista, there is usually a second partion on the harddrive that you can load by pressing F8 (or F10 depending on your system) and selecting the repair your computer option (depending on your manufacturer, you might need to input a password, after that choose the repair your computer option or solve startup problems
In Windows XP load the disc and open the recovery manager.
Jan 01, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario Disk Boot Failure, insert sytem disk and press enter
If you have your original Windows install disk, you can boot off of that, and should be able to recover most of your files, assuming your drive has not died fully. Depending on how important your files are, you can send the drive to a drive recovery service. I did that a couple years ago, they were able to recover all my files but it was EXPENSIVE. $1200.
Feb 19, 2018 | Computers & Internet
When I try to boot up my Compaq Presario model no SR 1420UK, I get the message: “Windows could not start because the following file is missing or corrupt: <Windows...
You can download the hal.dll file from this site www.dll-files.com/dllindex/dll-files.shtml?hal most of the windows missing dll files you can find here.
Also download windows nt or xp boot image from the net and create floppies or cd rom from that to boot up.
IF YOUR HARD DISK IS AN FAT32 PARTITION ITS VERY EASY AND YOU CAN USE WIN98 BOOTDISK WHIHC IS SINGLE DISK AND CAN ACCESS THE WINDOWS SYSTEM FOLDER AND COPY THIS HALL.DLL FILE.
AFTER GETTING PROMPT GO TO
C:\WINDOWS\SYSTEM32
COPY THE HALL.DLL
problem solved
Jul 20, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
