Question about Whirlpool LGB6300 Gas Dryer
Whirlpool dryer WGD5300SQ0 when the dryer fist starts no problem, good flame. After a few minutes the flame goes out and does not come back on. It continues to tumble now smell of gas. Please help what do I need to replace. Thanks
  • Whirlpool
    Whirlpool Oct 22, 2013
    Hello Oscar. We are very sorry to hear about the concerns you are experiencing with your dryer. Please email us directly at Whirlpool.Digital@Whirlpool.com so we can look into this matter further for you. Please include your name, phone number, address, and the complete model and serial number for your unit. Please also include this reference number: 62866. Best regards, Ashley
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 93 Answers
Thats because your not getting gas check solenoids
hydeparkappliancererpair.com
Posted on Oct 22, 2013
SolutionGuy
  • 331 Answers
SOURCE: Whirlpool Gas Dryer
Yes, that is most likely the problem. Once the glow bar igniter glows so hot, the switch opens & drops power to the igniter.(The radiant sensor has continuity while cold & open when a flame is present.) At the same time, by opening it redirects power to the valve coils allowing them to open & gas flow to the burner assembly. The dying glow of the igniter fires the gas. However, if your igniter glows, the radiant sensor is good. In this case, you'd need to replace the gas valve solenoids.
Posted on Aug 01, 2007
SOURCE: Whirlpool gas dryer model #
The flame sensor is probably bad. This is located on the side of the tube the flame is in. Has two wires going to it. Try to short it out and see if the flame stays lit. UNDER NO CIRCUMSTANCES OPERATE THIS DRYER WITH CLOTHES IN IT WITHOUT THE FLAME SENSOR IN PLACE!!!!! The other problem might be air flow. If the duct is blocked the flame will trigger the high limit switch. Take the hose off the back of the dryer and turn it on. There should be a lot of air flow. If there is and the flame stays on the duct hose or outlet is clogged.
Posted on Jun 29, 2008
Maytag317
  • 1136 Answers
SOURCE: Whirlpool LGR4634JQ1 Ignites the first time, then will not ignite
Hi, You will need to change the coils on the top of the gas valve. They are a plug in coil. This is a very common problem. If you need assistance on how to change them or the part#, I can help you. I would need you model#.
Thanks
Vic
Posted on May 14, 2009
Maytag317
  • 1136 Answers
SOURCE: heat cycle stops/goes off
Hi Tony, The next thing I would checnge would be the coils on top the gas valve. The tend to not open after the get hot. This is a very common problem with the newer gas dryers. I hope this helps you. Let me know if I can help you further.
Thanks
Vic
Posted on May 15, 2009
mgprice
  • 744 Answers
SOURCE: dryer heat shuts off
Hello, reading between the lines I'm going to assume you have a gas dryer. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Posted on Jul 24, 2009
What causes my gas dryer to heat and the flame goes out
Try using timed dry insted of sensor dry if runs ok you need aew sensor strips. also make sure dryer vent is clean.
Aug 10, 2014 | Whirlpool Dryers
Whirlpool Model LGN2000KQ0 ignighter glows, flame turns on for a few minutes then it goes out and the ignighter never glows again nor does the flame return
The problem is the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help troubleshooting a gas dryer
Sep 25, 2010 | Whirlpool GGQ8831L Gas Dryer
Dryer starts up and flame starts for about 3-4 minutes and then flame goes out.
The pilot light lights? Then goe's back out? There is two stiff wires right in front of the flame. One of them is an ignightor, and the other one a thermocoupler. Or may just be one. That is the ignightor and thermocoupler. The thermocoupler is what detects that the pilot light lit. Its a saftey feature. It makes sure that there is fire before it turns on the main gas. So it wont blow up. It gets a film built up on it from the gas. Take some real fine sandpaper, or steel wool and clean it real good.
Then try again. It should work. If not then it needs to be replaced
May 21, 2010 | Whirlpool LGR8648 Gas Dryer
Whirlpool gas dryer Model #WGD5530SQ0 not heating properly
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Feb 04, 2010 | Dryers
Gas dryer ignites but wont stay lite
Try shorting out the Hi-limit sensor(Lg calls it that, don't know for whirlpool). See if that does anything. If it fixes that, don't leave it like that. replace it and the other fuse by it as well.
Nov 30, 2009 | Whirlpool Dryers
Whirlpool wgd5300sq0 dryer get hot then cools down. I replaced the thermal fuse as this was the cause the last time this problem was obsereved, however this time the problem has not be resolved. If I shut...
Sounds like the thermal cut-off is kicking in. Try checking the vent to make sure its not blocked and causing it to overheat, this would cause the cool down (the other candidate is a bad fuse, but if you fixed that already I would leave that for last)
Nov 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer heat shuts off
Jul 24, 2009 | Whirlpool Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Whirlpool LGB6300 Gas Dryer Logo
108 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
