Samsung wa13 UP
Smoke came out of machine,motor is done
Samsung front loading washer started smoking while on spin cycle , new rubber seal an bearing ?
my first though would be to consider if its electrical smoke of friction smoke, chances are if it smokes on spin the motor is over heating and ready to pack in its operation, new brushes may solve the problem before buying a complete new motor.
Sep 21, 2016 | Samsung Washing Machines
Model wf350anw01. bunted smell, smoke come in out door has direct drive motor
have a technician check it out but it sounds like a burnt out motor
Dec 04, 2015 | Samsung Washing Machines
Samsung front loader smokes
Please do not run machine with smoke coming from washer. You could create a fire. Unplug power cord, and call a qualified service person.
May 12, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
I have a 90 series washer and I just changed the motor coupler. Now the washer emits a electrical burning smell. what can I do?
not proper fitting has been done so motor is jammed,,,not moved freely so the burning smell is from motor ,,,disamble & assemble properly,,,check brakes fitting also due to jammed motor
Mar 11, 2015 | Kenmore Washing Machines
Samnsung Front Load washer; stopped spinning/agitating and smoke billowed out at end of cycle. Now washer will fill, but not agitate/spin or turn at all. Drum spins smoothly by hand. I'm guessing moto
the DC motors seldom go out but the motor control panel can and a burning oder/smoke would be consistent. I would expect a service technician would have to diagnose. This can get expensive.
Oct 20, 2014 | Samsung WF218AN Front Load Washer
Smoke coming from the back of unit and inside the drum.
may be motor burn if the smoke came at back, reason is overheating due to overload or leaking.
call the technician for your safety and not to waste money.
Oct 31, 2013 | Samsung WF203ANW Front Load Washer
Smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Oct 06, 2008 | Frigidaire GLWS1339CS Top Load Washer
Smoke from washing machine
CHANCES ARE ITS THE MOTOR START MACHINE RUN IT IF POSSIBLE FOR A FEW MINUTES TILT MACHINE BACK AND FEEL THE MOTOR IF IT IS HOT YOU NEED TO REPLACE IT (THE MOTOR)
Dec 11, 2007 | Washing Machines
Smoke smell coming from my 80 series Washer
do you actually see smoke or is it you have a burning smell
if you have a smell the motor may be overloading on spin
sometimes this is due to too much soap powder in wash
and when machine spins the water cant get away due to soap suds under and around bowl
acts like a brake on motor
try no soap powder in next wash
a good way to tell is that you still have soap in washing if you lift the lid (with no soap powder added)
Dec 02, 2007 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
