Question about RCA F25442 25" TV
Need to put it in av mode can't figure it out its in cable front mode help please
Im trying to hook up my xbox 360 to my digital lifestyles flat screen and cannot figure it out :((
A USE HDMI CABLE FROM XBOX TO TV AND SELECT HDMI AS THE IN PUT ON THE TV OR USE A HDMI TO AV CONVERTER AND PLUG AV PLUGS IN TV AND SELECT AV IN PUT ON TV
Jun 08, 2014 | Video Game Consoles & Games
I cannot figure out how to connect the Yamaha natural sound av receiver rx-v463 to the TV. I cannot get sound out of the receiver. What cords do I need?
If you want to listen your TV on your Stereo system thru your receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the Receiver..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Thanks
Jun 23, 2011 | Audio Players & Recorders
I have a 27N-S100 TV. It was given to me with no remote. The Cable plug thing in the back is completely broken off, but I was told the TV could work perfectly by using the 3 colored cables (I believe they...
What you're trying to do shouldn't work unless the VCR has a digital tuner in it or your cable company still hasn't converted over to digital as of yet. You will need to get a digital cable box from your cable company.
Connect the av cables to either the front or back of the television. I believe the front is av/video 2 and the back is av/video 1. You have to choose either video 1 or video 2 from the television's menu in order to access these parts of your television.
Connect the cable box to the other end of the av cables and you should be all set. You would change channels with your cable remote and always leave the Sharp television on video or
What you're trying to do: Connect the cable to where it says in on the back of the vcr. and connect the av cables to the vcr where it says out. You will have to do a channel scan on the vcr.
Apr 26, 2011 | Sharp 27N-S100 27" TV
Nothing show up on tv screen after plugging in the cables. the HDMI and the AV cables too.
Hi, try the following
1 using the av lead and not the hdmi so plug the av lead into your tv and make sure your tv is on the correct input
2 turn the ps3 on at the back
3 now press and hold the on button down until the ps3 switches itself back off
4 then press the on button again, doing this resets the video mode from hd back to standard av so once you have done this you should have a picture on the tv, if not check your on the correct input
if you have done the above and it still dont give you any video than please let me know then ill do my best to assist you further ok
please rate this solution, thanks
Dec 13, 2010 | Sony Playstation 3 (PS3) Console
Trying to connect a PS3 to my hotel room tv. I have 3 color AV cords, and I´m putting each accordingly on yellow, white and red, but can´t seem to see or hear anything on AV source. What am I...
did you set to AV 1, 2, 3 or DVD input, it is depend to where it connected to..whether you connect to the AV input front panel, or rear. if not sure you can connect it to the front panel and sequentially sets the AV source, if still the same. you can connect the cable to the DVD input should be the type of cable TV .. PS 3 is like this:
Connect red, green blue Plug/jack accordingly to each colour on DVD INPUT the TV. set AV Source to DVD.. please Try and if the same result , you have to replace the AV cable of PS3.
Oct 20, 2010 | Protron PLTV-32 Television
I have Time Warner cable. I have a Symphonic SR90VE vcr/dvd that I have hooked up to the main TV. The cable box services a second tv in another room. I can't seem to get the main tv and the vcr/dvd player...
Cable goes to vcr cable INPUT, then run cables from vcr OUPUT to tv INPUT or AV.
Then put tv on input or av channel or channel 4 and use put the vcr on the channel you want to record.
Apr 19, 2010 | Televison & Video
I cant figure this out about my headrest lcds HELP
Let me guess, you have a pioneerr dvd headunit a video amplifier and 2 headrest correct.
Now connect from V/A in at the headunit to V/A out at the video amp. Connect V/A out put from #1 headrest to #1 V/A in put at the amp. And V/A out put from #2 headrest to #2 V/A in put at the amp.
Jan 07, 2010 | Car Audio & Video
Playstation 2 and 3 won't work on Sylvania 6432TE tv.
If you are using the Yellow, Red and White cables I believe you have to put your tv into AV mode. There should be a button the the remote or sometimes there is one on the tv
Mar 30, 2009 | Sony PlayStation® 3 (80GB) Console
Help
how are you connected to your tv? if your are connected in HD mode (hdmi cable) you will only get a 16:9 picture... SD mode (AV cable, S VIDEO cable, Component AV cable or SCART) will transmit a picture of 16:9 or 4:3 (4:3 being the old 'square screen' mode)
Oct 01, 2008 | Sony Playstation 3 (PS3) Console
Have A durabrand remote and cannot figure out what channel to use to watch dvd's
est1964-I am guessing that your tv is a duabrand, did you try to put in 00 as a channel alot of tv's use this as AV input,if not try to channel down to AV mode this is fairly common.Try that out and let me know,maybe we can figure this out. cooltek Feb.18/08
Jan 12, 2008 | Durabrand DWT1304 13" TV
RCA F25442 25" TV Logo
21 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
