Question about Samsung AP500PF Air Conditioner
Error code es 54 - Samsung AP500PF Air Conditioner
    New Friend:
    Problem Solver:
  • 12 Answers
Did you try a power cycle? I know that sounds like a catch-all answer, but it has worked for me in the past. I had this same air conditioning unit, and it used to give me this code frequently. Flipping its breaker always fixed the problem for me. Good luck.
http://www.a-ccontractors.com/
Posted on Jul 21, 2015
Trying to backup iPhone 6s on my computer using iTunes and keep getting error code 54.
Please refer to the following link:
https://www.imobie.com/support/how-to-fix-itunes-sync-iphone-error.htm
How to Fix Unknown Error (-54) about iPhone/iPad/iPod Cannot Be Synced Sometimes fixing your iTunes sync error (-54) seems a little difficult because it is hard to find which files cause this problem. In this case, you have to sync separately to find what kind of data you can't sync. For example, you can sync only songs to iPhone 6 or iPhone 7 to check whether the music files cause this unknown error (-54).
Of course, there are some common tips you can try to fix this error:
  • Update your iTunes to latest version, now the latest version is iTunes 12.6.2.
  • Upgrade iPhone/iPad/iPod touch to latest iOS operating system. Now you can update to iOS 10.3.3. (The iOS 11 will come out soon, you can update to it when it is available.)
  • Authorize computer in iTunes.Open iTunes > Choose "Store" on iTunes menu and authorize your computer.
  • Change permissions of your "iTunes" folder or original files/folder. You can find the originals that you want to transfer to iOS device and change permission. iMore give us one example to change "Read Only" permission of "iTunes folder" to fix iTunes sync error (-54) on Window 10:
    Open Windows Explorer > Go to "Music" folder > Right Click "iTunes" folder > Properties > Uncheck "Read Only".
  • Run iTunes in administrative mode. Sign in to Windows as an administrator > Right click iTunes icon > Select "Properties" > Select "Compatibility" > Check to run as administrator.
  • (For Windows iTunes users) Install all available Windows update service packs. iTunes sync error may be caused by incompatible driver on your windows pc.
  • Use an iTunes alternative After trying solutions mentioned, if your iPhone still cannot be synced due to unknown error occurred (-54), you can try some iTunes alternative, like AnyTrans. As one of the best iTunes alternatives, AnyTrans allows you to transfer media files (like Music, Playlists, Movies, TV Shows, Podcasts, iTunes U, Audiobooks, Voice Memos, Apps, Ringtones, etc.), and won't erase the existing data on your iPhone iPad. Click Here to Download AnyTrans >
Oct 11, 2017 | Cell Phones
I'm working on the 2004 Jeep Grand Cherokee 4.7 showing error codes
lashes 52 and 54 ,you do mean flashes ? What flashes ? Check engine light doesn't flash codes .
Apr 24, 2017 | Jeep Cars & Trucks
How to fix code 54
The problem with the fuel pump? EGR error?
Apr 24, 2017 | Dodge Cars & Trucks
I have a Frigidaire LAD504TDL dehumidifier and code 'ES' shows on display. What does this code mean? Unit runs but not much water in tank.
Good Morning Mark, thank you for your post!
I see that your Frigidaire dehumidifier is displaying an error code of "ES" and you would like to the meaning of that error code. The "ES" error code stands for evaporator thermistor error. This could be a possible problem with your control panel, thermistor, or a wiring harness. I would recommend contacting your manufacturer for further assistance with your dehumidifier. Best of luck! -Matt
Jun 08, 2015 | Frigidaire Dehumidifiers
Error code 54
http://www.pc-library.com/errors/error-code/54-0x36/
Mar 08, 2013 | Biostar Computers & Internet
I have a savin 9113Z that is flashing a 54 error code.what is wrong?
Chekc or replace the fuser unit thermoswitch and thermistors.
May 16, 2010 | Office Equipment & Supplies
Ricoh ft 3713 error 54
Clean the thermistor and clear the code by turning on both dip switches on the main board, turn off the main switch, turn off the dip switches, turn on the main switch.
Mar 26, 2009 | Ricoh FT3713 Copier
7150C Error Code #54
This error means your purge unit is not working. Most likely there is a piece of paper stuck in the unit (or other object).
You will have to take the unit apart and check for objects inside that should not be there. Also, check to make sure the excoder strip is seated correctly in the printhead (this is a long clear strip that goes from one end of the unit to the other).
If neither of these fixes the error, then the purge unit would have to be removed, inspected and repaired or replaced.
Feb 22, 2008 | Brother MFC-8220 Fax
Samsung AP500PF Air Conditioner Logo
105 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
