Question about Irons
Looking fir instructions for a Sisan garment Steamer
4 Suggested Answers
laura_b1215
  • 15 Answers
SOURCE: I have lost my operating
Check out a video manual on Conair Fabric Steamer
at http://www.handbooklive.com/
Click on Appliances category. The video instructions are for GS4 model but it must be similar.
Hope that helps
Posted on Sep 06, 2008
laura_b1215
  • 15 Answers
SOURCE: Re Conair garment steamer ctx12c
check out www.HandBookLive.com for a video manual under Appliances category (both GS4 and GS10 models have videos and show how to attach a hose in a Quick Start chapter- I am just not sure about the model you are asking about. It could be different
Posted on Nov 05, 2008
  • 1746 Answers
SOURCE: how to unclog a garment steamer
Hi, Try puting a cup of white vinegar in and let it sit over night. It should disolve the build up of calcuim. Also try CLR it also will work. Good luck.
Posted on Nov 05, 2011
Why do water drops form om my clothes while steaming
You have a build up of water In the hose. Sometimes happens because the hose is too low to the ground. Try stretching the hose up and tap it and the water should travel back down the hose.
Another reason could be that you are using too much steam for that particular fabric.
Jul 08, 2014 | Rowenta Commercial Garment Steamer - White
Use Manual Garment Steamer Model PS-300
If you have the Home Pro Professional Garment Steamer PS-300 from Homedics, the Homedics website has the manual on their support page. Go to http://www.homedics.com.ph/instructionbooks/ .
then use the drop down menu to select the PS-300. Click on Download to get the instruction book. Note: the file is a PDF, so you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Jan 20, 2014 | Irons
ROWENTA IS8050 INSTRUCTION MANUAL
Rowenta IS8250 Garment Steamer instructions are no longer available from Rowenta.
May 28, 2012 | Rowenta Commercial Garment Steamer - White
How to unclog a garment steamer
Nov 04, 2011 | Rowenta Commercial Garment Steamer - White
I have a panasonic unwrinkler garment steamer. how does it work
Friend has exact same model in the box with instructions and help centers repair numbers. Do you still need help? Want a new hardly used 1?
Oct 07, 2009 | Conair Compact Garment Steamer Iron
How to use a steamer.
  1. Plug in the steamer.
    • The steamer usually comes with a smallish padded square with a strap that slips over your hand. (If you so not have one of these, cut out a square from some stiff cardboard, pad it using cotton batting, and cover it with a heavy, smooth, waterproof or water-resistant material.)
  2. Make sure it is steaming nicely before you use it. You check by pulling the little trigger on the handle, and seeing how much steam issues when you release it. You actually want to use this while steaming as well, in order to release more steam when needed.
  3. Hang the garment, and slip the padded square over one hand.
  4. Place the hand with the square on the underside of the garment, and use it to keep the fabric smooth while you steam it.
  5. Use the steamer by holding the nozzle close to the garment, and pulling both it and the padded square in downwards strokes.
Sep 18, 2009 | Rowenta Commercial Garment Steamer - White
When using steam iron i am left with a puddle of water on the floor how do i control the amount of steam
I think is maybe the hose connections. You need to make sure both ends (by the T-nozzle and by the body of the steamer) are secure. You have to align the nozzle with the rod, and push down, and twist. Try watching instructions for connecting both ends on www.HandBookLive.com under appliances category. There are GS4 video instructions and GS10 (this one has just been posted yesterday)
hoe it helps. Otherwise I would return the steamer. Nowhere in the operating instructions does it say that you can control the amount of stream produced...
Laura
Sep 27, 2008 | Conair Compact Garment Steamer Iron
I have lost my operating instructions, I have a Conair G3 compact garment steamer and want to use it, how do I start. Thank you for your help.
Hope that helps
Sep 03, 2008 | Conair Compact Garment Steamer Iron
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Irons Logo
76 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
