Question about Conair Lighted Mirror
In bulb replacement for BE67 mirror on which side does the blue bulb go
2004 gmc 2500 i have heated folding turn indicator side mirrors.turn indicator is not working on driver side.is it possible to repair ot do i need to replace?
I'd call a GMC dealer and ask for the parts department. I'd ask about the availability and price of the driver's mirror turn signal bulb. That might tell you if that bulb is replaceable. You could also ask that same delaership's service department about the labor cost to replace the bulb.
If the plastic cover below the mirror will not snap off, you would probably have to remove the mirror from the door and take it apart to replace the bulb. Depending on the friendliness of the GMC service or parts department , they might tell you what to do here.
Jan 18, 2013 | Cars & Trucks
How to replace the bulbs on the Conair BE103 make-up mirror
I HAVE JUST REPLACED A BULB ON MY MIRROR MINE HAS 2 SCREWS EACH SIDE OF THE MIRROW,UNSREWED THEM AND THE BACK COME OFF TO SHOW THE INSIDE AND THE BULB, SCREWED THE BULB OUT & REPLACED IT.
Jan 14, 2013 | Cars & Trucks
How do you get the mirror apart to change the light bulb?
Here are the instructions, basically you remove the screws on each side and then on side will lift off. I used a flat head screw driver to work around seem until it lifted off. Hope this helps.
http://www.conair.com/instruction_booklets/06PM8043%20BE18NX.pdf
Jun 16, 2011 | Conair Chrome Double Sided Lighted Makeup...
On my 2008 ford F350 the driver side mirror marker lights are not working. I need to know how to repair them. Thanks
If it's just that the bulbs that have burnt out you'll need to position the exterior mirror glass inward toward the vehicle.(Note: Use caution to not trap the side lamp assembly wiring during installation, or damage to the wiring may occur.) Using a flat blade screwdriver or something similar, push the mirror side lamp assembly forward while releasing the retaining clip. Separate the bulb holders from the mirror side lamp assembly and remove the side lamp. Replace the bulbs and reassemble. I hope this helps you out.
Mar 08, 2011 | Ford F-350 Cars & Trucks
I cannot get the side mirrors apart to change the bulbs on my 2008 ford super duty truck. The mirrors are heated.
- Adjust the mirror so the mirror glass is in as far as it will go (meaning if you were looking in the mirror you would see the side of the truck)
- Look inside the mirror housing
- Locate silver clip
- Using a flat screw driver, push the clip in
- Lenses will pop out on the outside
- Remove bulb
- Replace bulb
- Snap back together when new bulb in place.
Oct 10, 2010 | 2008 Ford F 250 Super Duty 4WD
How do you install turn signal lens on side mirrors on a 2005 F250?
- Remove bulb
- Replace bulb
May 02, 2010 | 2008 Ford F-250 Super Duty
Replacing the Mirror Light - driver's door
I assume your question is how to replace the bulb in the side mirror. Can you please tell us the make and model of the car.?
Thanks,
Jan 24, 2009 | 2002 Volvo S80
How to replase turn sign bulb in side mirror.
Find out how to open it up, then take out bulb and buy replacement at Auto Good stores like Kragen which might tell you how to do it.
Nov 06, 2008 | 2004 Acura TSX
Replace passenger side power mirror clearance lamp (bulb only).
If you are facing the passenger side mirror adjust the top (large) mirror so that it is turning in towards the truck as far as it will go. Then look behind the mirror in the bottom righthand corner (outside bottom corner) and you will see a silver metal clip. Take a straight head screw driver and push on that clip and the lens will pop out. Then you simply unscrew the bulb holder from the lens and replace your bulb. Good luck!
Oct 16, 2008 | 2008 Ford F-350
Replacement rear brake bulb
He probably bought the wrong bulb. Look in the manual. They list the correct bulb numbers, so check that. It could also be that your mirror bulb decided to burn out at the same time. Also, check the fuses, see if one burned out. Look in your owner's manual to find the fuses and the right one.
Jul 24, 2008 | 2004 Ford Freestar
Conair Lighted Mirror Logo
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
