Question about Samsung AK59-00104R Remote Control
How do I turn on closed captioning on the AK59-00104R Samsung
4 Suggested Answers
  • 205 Answers
SOURCE: turn on closed caption on samsung LA32S81B tv
If you don't have the manual, go to this website:
http://www.samsung.com/in/support/productsupport/download/FileView.aspx?cttfileid=1383390&type=TV&typecode=&subtype=LCD+TV&subtypecode=&cmssubtypecode=&model=LA32S81B&filetype=UM&language=&LSSI=/in/module/ssi/left/lmenu_tv_sonomatrenz.sec&RSSI=/in/module/ssi/right/rmenu_tv.sec
and download it. I think Samsung refers to it as Teletext. Instrucitons are on page 31 of this manual.
Good luck.
Posted on Dec 09, 2007
SOURCE: Samsung LCD does not display closed caption w/DVD player
buy a devant lcd tv
Posted on Mar 05, 2010
kidsasuke
  • 121 Answers
SOURCE: Can't turn on closed captioning and subtitles
If it's only with some DVDs, then the problem likely lies in the DVD itself not containing any subtitles or CC.
Posted on Jun 03, 2010
How do I turn off the close captioning on my dvd box.
Go into menu go to display and closed captioning is a option click on it and it will allow you to turn it off. Beware some DVDs have closed captioning options on the disc, just go into set up on the disc and it will give options.
Oct 17, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
Samsung LN-T4061F
To view the captions, all you have to do is turn on the decoder by following these simple steps:
  1. Access your TV menu screen using your remote or by pressing a button on the face of the TV.
  2. Select the closed captions heading. Several different caption options may appear.
  3. Select the "CC1" option.
  4. Exit the menu.
Closed captions should appear within approximately one minute of adjusting this setting. If they do not, review this portion of your television's operating manual or contact the manufacturer of the television set.
Public Television stations do not transmit Closed captioning
Apr 23, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
How do I turn off the subtitle / closed captioning on a Samsung series 6 6300?
Is the captioning coming from a source such as a Sky box? If so, you need to switch off closed captions on the source box and not the TV.
Sep 07, 2014 | Samsung UE40B7020 40 in. LED TV
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
How do I turn ON Closed Captioning.
It sounds like that option is not available on that model , contact samsung
Dec 07, 2008 | Samsung DLP HL-P5663W 56" TV
Insignia TV and Direct TV Remote issue - cannot get the closed captioning turned off
The TV slowly, all by itself, ran closed caption on the major stations.
Unable to turn off through the menu as that option was greyed out.
Now all channels have this unwanted closed caption.
Any similar problems and ideas.
Thanks, Harold
Jul 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung Rear Projection DLP HDMI Captions
The captions are turned on in the cable box itself. If you have a Motorola cable box, turn it off then hit the menu button for the cable box. You will then see where you can turn off the closed captioning. Anymore questions email me tvtek@msn.com
Nov 29, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Closed Caption
closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Apr 14, 2007 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Samsung AK59-00104R Remote Control Logo
29 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
