Question about Samsung SGH-ZV40 Cellular Phone
Text Alert Hi I received a text Alert tone and saved it to my phone when I go into set this as my tone alert it does not come up as an option. Is this not available on this phone. Thanks
Joux
Posted on Mar 05, 2008
Joux
SOURCE:
Why does my samsung s380c phone have no text or voice mail alert signal
Menu > Messages > Msg Settings > General > Message Alerts
By default, this setting is "Off" - which makes absolutely zero sense. Try setting it to "Once", "Every 2 Minutes" or "Every 15 Minutes"
Changing this setting didn't help the no text alert issue with the Samsung S380C I'm dealing with, but it might work for you.
Feb 19, 2013 | straighttalk.com
How do I change the incoming text notification to alert more than once, I sometimes don't hear the phone and need it to alert more often until the message is cleared. Is this possible?
Hi.hope this helps.Go to the setting menu of your phone.go to TONE setting..message alert tone and choose desired option if you want it to ring several times..
Jun 21, 2011 | LG P500 Cell Phone
My LG shine does not alert me when I receive txt messages. how can I change that?
Hello
Your phone is probably on silent or you havent selected a tone for your text messages. Go to your tones,select a particular ringtone you want to use for your text mesages select "options" and select ''set as message alert tone" and select ok.
Jun 09, 2011 | LG Shine KE970 Cellular Phone
My sidekick lx text alert tone does not work. the sidekick does not vibrate or make a sound when i receive a text.
This most likely has to do with the sound profile that you currently have set. Go into the sound options, see if there is a detailed option available to increase/decrease the ring volume or vibration.
Some phones have the option to turn on an alert and vibration for text/incoming call.s
May 02, 2011 | Cell Phones
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Motorolla Phone
Hi
All you need to do is to scroll to settings on your phone then you go to tone settings,from there you go to Message alert tones and check if your message alert tone is off.if it is off then you have to select a tone then you can start hearing the sound when you receive text message.
THANK YOU
Jun 15, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
How to change alert tone for incoming text messages
go to the tone, click on options or set as the go to alert tone then it should say text picture or something else.
Mar 31, 2010 | Samsung Gravity SGH-T459 Cell Phone
INSTEAD OF RINGTONE, I GET A SINGLE BEEP
your phones alert tone was set to beep once, to change this go to profile settings then open the activated profile such as general>personalize>message alert tone then now choose the ring tone you want to use as message alert tone..
Jan 30, 2010 | Nokia 6101 Cellular Phone
How can i change my text message tone on my samsung f480 thaks
Please Follow these steps to change
  1. From the standby screen, press Menu.
  2. In the main Menu, press Settings.
  3. In the Settings menu, select Phone profiles and press.
  4. You will be presented with a list of phone profiles for different situations and environments. The one you're currently using will be ticked. Highlight the one you want to use and press the Edit button at the bottom of the display.
  5. You are taken into the profile settings. At the top of the list you'll notice three tab icons - these represent (from left to right), ringtone, message alert, and keypad sounds. You can switch between settings for these by tapping one of the tabs.
  6. Tap the message alert tab (in the top centre of the display). A set of message alert settings appears. You can change the Message alert type, if you want to, by tapping the panel and choosing the appropriate option.
  7. To change the Message alert tone, press the Message alert tone panel. In the menu that appears, press Change. Then choose one of the options Use effect tone (one of Samsung's pre-loaded effects) or Use my alert tone (allowing you to choose from your own sounds). In this example, press Use my alert tone.
  8. Press the Sounds option (Figure 16). In a similar way as changing ringtones (above) you now have the choice of choosing from your Music files,Ringtones that are loaded onto the phone, or My voice clips. In our example, we'll again choose a file from our Music folder.
  9. Press the Music option. A list of suitable MP3 tracks appears. Tap the one you want in order to highlight it.
  10. Press Options, then tap on the Select menu option to install it as your message alert.
  11. You are now taken back to the Normal profile settings, where the Message alert tone has changed. To save this change, press Options and then Save. Alternatively, press Back and you will be asked whether you want to Save? Press Yes.
Thank you Sir, Have a nice day.
Sep 26, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
How can I set repeat incoming text alert tone till text is read.
this should be in sound setting its absending you want set it on
Aug 14, 2009 | Cell Phones
Samsung SGH-ZV40 Cellular Phone Logo
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
