Question about Hobart D300 Stand Mixer
Hobart d300 mixer 3 phase no power will not mixer 10 cup flower
SOURCE: d300 hobart mixer
i have a spare unit for dsale 1500.00 cdn
Posted on Oct 23, 2008
bigg t
  • 640 Answers
SOURCE: Problem with Hobart D300 Mixer
Sounds to me like the shifting yokes are locked up,or a broken shaft.Is there any noise?
Posted on Dec 13, 2008
bigg t
  • 640 Answers
SOURCE: hobart 600 wiring connection
The ground wire attaches to the ground lug under the top.
Posted on Mar 17, 2009
  • 3600 Answers
SOURCE: electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Posted on Jul 24, 2009
tooltech75
  • 80 Answers
SOURCE: wiring diagram for a Hobart D340 40qt mixer
i read in the manual that the wiring diagram is located on the inside of the top cover. check it out..
good luck
Posted on Oct 08, 2009
Previously hard wired. How do I connect a power cord?
It doesn't really matter which wire goes to L1 L2 or L3. All that can happen is it will run in the wrong direction. If it does just interchange any 2 of the L1 to L3 connections and this will reverse the motor.
Dec 08, 2015 | Hobart D300 Stand Mixer
I have a: H-600T. Serial #11-369-290. Is this a 1,2, or 3 phase?
It's either 1 or 3 phase. Check the data plate. If it has a two pole contactor it is three phase, if it has a three pole contactor then it is three phase.
Jan 07, 2011 | Hobart D300-6036 Mixer
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
I have a Hobart 80 qt. stand pizza dough mixer that has lost forward speed, and only works in reverse. Is this electrical controls or a gear problem?
if the mixer is a 3-phase unit, that mixer has no reverse speeds, all gears should turncounter-clockwise when mixer is on ,if a 3-phase unit try switching any 2 of the incomingline to to change direction
Oct 08, 2009 | Hobart D300 Stand Mixer
Can I cange 3x230v up to 400v
Are you stating you have an A200 mixer that is 3 phase 230 volt?
I was under the impression all A200's were single phase. The D300 floor model came 3 phase. In any regard, to change the input voltage to any maching, you would have to replace the rotor, stator, and control group, including wiring. It has to be kept to orgiinal specifications, and tech support would have to authorise the change. As you can imagine, it's not really an option. If you change from 50 to 60 Hz, you would have to change your worm gears also.
Oct 03, 2009 | Hobart A200 Stand Mixer
Electrical connection of hobart h600
Jul 24, 2009 | Hobart H600 Stand Mixer
Hobart mixer model D 330 with 3 wires disconnected
You can go to the www.hobartcorp.com website and register to download a parts manual.
You may be able to get the wire attachments from that.
Click on the operator and service manuals link. You will have to register.
May 07, 2009 | Hobart D300-6036 Mixer
Need to know what type motor is in a hobart D 300 mixer
Look on the I.D. plate. Voltage should be listed. "PH" is for phase. It will either be single (1), or three (3) phase. "AMP" is for ampacity or the amount of power it consumes. Hobart's manual does not list the motor as an entire replacement unit. It only lists parts as if you were to rebuild the motor. Sorry.
Hope this helps some.
Apr 11, 2009 | Hobart D300 Stand Mixer
Need to replace a cord on a 30 quat hobart mixer and need to know where positive negative and ground go
I need to know if the mixer is 1 or 3 phase.Look at the plug---does it have 3 or 4 prongs?
Nov 30, 2008 | Hobart D300 Stand Mixer
Timmer assembly
this a 115 volt single phase timer you can buy the timer at hobart.com or jump the timer by jumping the red and brown wires but the timer will not work if you want the phone # of hobart tell fixYa to email me and i will leave the number they are located in jackson hieghts N.Y
Oct 30, 2008 | Hobart D300-6036 Mixer
Hobart D300 Stand Mixer Logo
19 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
