Question about GARDENA Water Timer
Gardena c 14e I have one of these that opens for
Gardena c 14e I have one of these that opens for a second and immediately closes again. I replaced the battery, which was brand new, and then replaced it under warranty (was only a day old) but it still won't work. What else could be wrong?
2 Suggested Answers
SOURCE: Gardena C 14e - instruction manual needed please
Possible Gardena manuals are found on following link:
C14 manual does not show, but the T14e has very similar buttons and that manual does show
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Posted on Oct 05, 2011
My gardena water timer won't stop bipping. See the picture. Is it the battery ?
for the Gardena-T-1030-1805 model....
Gardena 1030 1805 Operating Instructions Manual Page 7
11. Battery
11.1 Status indicator
If the battery capacity falls below a certain level, a warning signal sounds every 15 seconds. The programs you have set are not run. The water flow cannot be opened manually. If a valve is open, however, it will be closed.
11.2 Changing the battery
If the battery capacity is too low (the warning signal beeps every 15 seconds), you must change the battery.
To do this, the water timer must be removed from the tap.
Important : Changing the battery deletes the data you have set.
To change the battery :
1. Insert the battery in the battery compartment
2. Set the Run Time control knob
3. Reset the watering data as described in "Setting the watering data".
3 If the Run Time knob is not turned to Reset, 5 seconds after the
battery was inserted the current Run Time shall be accepted. This is confirmed by a double beep.
Note : The time the battery was changed is taken to be the starting time.
To ensure that the water timer works properly we recommend that you insert a new battery at the beginning of every gardening season, or at the latest after a year.
Important ! Please dispose of used batteries properly at the appropriate communal waste disposal site. Only dispose of batteries when flat.
May 28, 2016 | GARDENA Hardware & Accessories
Gardena C14e water timer won't start.
1) Copy following link to identify timer and download manual, to see if there is a reset protocol:
2) If functionality cannot be restored, buy another timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 13, 2013 | GARDENA Hardware & Accessories
I have a Gardena water timer T1030 D rthat starts at the right time but don't close even not in manual on/off. What is wrong and how to solve it?
Reset timer to clear programs, and try programing again.
Copy following link for Gardena timer manuals
Jul 14, 2012 | GARDENA Water Timer
We need a replacement part for our Gardena Garden timer. The part we need is a Rubber diafram. It is black and it has a post and spring going through the center of it. Where can I get replacement parts?
I don't have a source of Gardena parts, and have asked anyone finding this thread to add a comment if they find a Gardena parts source.
Compounding the problem is the company doesn't respond to e-mail requests, many Gardena products do not have on-line manuals, and Garden timers sometimes have more than three different numbers for the same timer making it difficult to identify exact timer.
Open following link for Gardena resources:
http://www.gardena.com/ca/en/sitemap/
Jun 26, 2011 | GARDENA Water Timer #31169-4
When is ON the timer admit a water jet and after that the valve is closing even if the battery is full, the timer ON and the supply of water open. Thanks
Problem is not clear and timer not identified.
Open following link for Gardena resources including contact information for Gardena.
If timer is cracked, then electric parts can get wet and stop working.
If timer valve is not closing, maybe the timer is broken or something is stuck in the valve.
Add a comment for more help
Upvote the help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 09, 2011 | GARDENA Water Timer
I live in Indianapolis IN, and would like to return my gardena T 120 timer. Where do I send it in?
Gardena.com has contact us page
As a note, fixya gets more Gardena help requests than the other water timer product companies.
Upvote the help.
And take advantage of fixya expert assistance live.
May 10, 2011 | GARDENA Water Timer
Dec 30, 2010 | GARDENA Water Timer
Which gardena water timer will work the best?
Generally speaking, fixya sees more complaints about Gardena water timers than other brands. Maybe more Gardena timers are sold, or maybe the timers have problems.
There are no sources for water timer parts for any brand, and nobody reports being able to fix a water timer once it goes bad.
Any plastic outdoor device that works with a battery-operated clock motor cannot last more than a year or so, and will crack if exposed to freezing water.
I suggest the cheapest timer.
Sep 10, 2010 | GARDENA Water Timer #31169-4
Sun Roof Stuck open
tilt the sunroof into vent position as far as possible then press and hold the same switch for 30 seconds until you see it move release the switch and immediately press and hold it again the sunroof will close and open fully then close again do not release the button until it reaches the closed position for the second time.
source: owners manual
Sep 06, 2008 | 2003 Ford Focus
GARDENA  Water Timer Logo
56 people viewed this question
Top GARDENA Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Bill Boyd
Are you a GARDENA Hardware and Accessory Expert? Answer questions, earn points and help others
