Question about Canon PIXMA iP3600 Photo Printer
Canon Pixma ip3600 is dead - power light doesn't even come on. I have replaced the power cable, and plugged it into a different wall socket, switched computer off and on again, still no luck. It just went dead in the middle of a print, I had to remove a page from the back of the printer and it just never came on again.
yooperbud
  • 8637 Answers
SOURCE: Canon Pixma iP2000: yellow power light blinks-reset doesn't work
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
pagebor
  • 2785 Answers
SOURCE: Pixma ip3600 not changing to 2nd black ink tank
you cant swap it for printing you have to refill the empty one
Posted on Feb 01, 2009
SOURCE: my canon pixma printer won't turn on
I have the same problem. I don't really know what to do. Think its broken. guess we have to buy a new one, I'll buy an Hp instead. hehe
Posted on Jan 16, 2010
  • 5103 Answers
SOURCE: Canon Pixma ip3600 message saying printer is not online
This could be a problem with the port. If you have the printer attached to a USB hub, directly connect to the computer. Try connecting to a different USB port and test the current port with a known working device. Consider trying a new USB cable (minor damage could be a factor in signal loss).
I hope this helps.
Posted on Feb 04, 2010
Testimonial: "Thank you,I did replace the USB cable and all is well."
SOURCE: Canon Pixma MP610 will not print black ink. Page
kkdlist.wordpress.com/2010/07/01/14/
Posted on Aug 02, 2010
Canon MP210 no power
See that power cord is seated on both ends, Plug cord into wall and with a multi-meter see if you are getting voltage on other end of cord. Test wall socket. Try another wall socket. Replace cord.
Mar 30, 2015 | Canon PIXMA® MP210 Printer
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Pixma 810: Suddenly the printer is dead. Despite power cable is connected with Pixma I can no longer turn the printer on. Is there a fuse anywhere? What is the solution? Best regards Peter Widmer
Hi
First of all please make sure that all the cables from/to the printer are connected properly. Now please use different power socket to make sure that the printer is getting power. If so then we can reset the printer. To reset the printer unplug it from/to the power socket and mains and let it sit without power for more then 10 minutes and then replace all the cables and print a test page. If still the issue is not resolved then you'll need to replace the printer cable. Hope this helps...please post back for further assistance.
Daniel
May 19, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Canon IP3600, error # 6A80. Can't fix the issue
I have pixma ip3600 canon printer, been used 8months working fine, but today, when I turn on just wait for little whileand the amber light turn on, and when I open thetop cover the printer head won't move at all, please show me how to fix the problem. thanks. Email ( bui_lac972@yahoo.com )
Apr 13, 2011 | Canon PIXMA iP3600 Photo Printer
I hope this helps.
Feb 04, 2010 | Canon PIXMA iP3600 Photo Printer
Canon PIXMA IP3600 Service error 6C10, and doesnn't print at all
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Sep 27, 2009 | Canon PIXMA iP3600 Photo Printer
My canon Pixma MP780 suddenly would not turn on, after 3 years. Checked the cord, changed wall plugs, the lights flashed but then went dead. Help, pleeze
(1) Check the power cord
connection.
(2) Check the connection between
the SPCNT board (JPSU1) and
power supply unit.
(3) Replace the power supply unit.
That's what the service manual says for your problem!
Jul 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My Canon PIXMA iP4000 will not turn on. Printer was working great until i went to turn it on and there was no power.
Dear Mmally1323,
You said "My Canon PIXMA iP4000 will not turn on. Printer was working great until i went to turn it on and there was no power."
First off make sure that your powre cable is securely plugged into your printer and into the wall. If the printer still doesnt turn on then try to plug it into a different wall socket, as the socket could be 'dead'.
Jul 02, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon ip3600: New Printer doesn t recognize that
Possible solution:
In Preferences/Properties, make sure that "Automatically Select" is selected in "Paper Source"
Mar 31, 2009 | Canon PIXMA iP3600 Photo Printer
Canon PIXMA iP3600 Photo Printer Logo
56 people viewed this question
old marine
old marine
