Question about Sewing Machines
How to operate a Cehisa Pro-8 Edgebander - Sewing Machines
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
Huge question! Sounds like you need a professional to come in and train. Well worth the $$ as they can teach you maintenance which edgebanders need so much of. I do a Preventative Maintenance and train at the same time so the results are obvious. You could get a hold of Adwood if you're in the states for manuals.
Posted on Jan 05, 2015
Can i fina a find manuel for a dressmaker singer sewing machine made in the 1950-1960s
Euro Pro Dressmaker 998B Owner Manual
also customer service is:
888-633-8635
Average Wait: 31 mins - Monday through Friday, 8:00 a.m. to 4:00 p.m. C.T.
the online manual is below:
http://www.manualslib.com/manual/451796/Euro-Pro-Dressmaker-998b.html
hope that helps if not let me or someone here know and will do our best to help you.
Aug 19, 2014 | Euro-Pro Dressmaker 998B
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
I do not have a problem with the machine. I am curious about the plate numbers. On an american sewing machine, the plate the fabric feeds through, normal have 1/4, 5/8, etc. On the Euro Pro Denim Model ...
So an American machine has imperial seam guides on the needle plate.
But the Euro Pro would be European and in metric so it has seam guides in metric widths, i.e. millimetres. 10 will be 10 millimetres, or 1 centimetre, 16 mm, 22mm.
A normal seam in metric is 15mm - in your land 5/8", the two are not quite the same but pretty close. This link http://convert.french-property.co.uk/ gives you a converter between the two systems.
A 1/4" is your standard piecing seam for the quilters and this is why many Australian quilters will buy a 1/4" foot so they can guide the fabric along the foot edge to get nice standard seams.
So you could break out some masking tape and a metric/imperial ruler and measure from the needle to the right and put a strip of tape onto your needle plate to mark your 5/8" dimension you are used to. Or use the 16mm seam marking which is very close anyway.
Hope this helps.
Mar 09, 2011 | Euro-Pro Denim Sewlution 380 Mechanical...
Euro-pro 9110. just received one this weekend.. when i finally put it to use, it turned on and then a sound and off again.. it smelled like it burned.. anything I can do??
The 9110 has a 25 year warranty.
The manufacturer's information is:
EURO-PRO Operating LLC
94 Main Mill St.
Door 16
Plattsburgh, NY 12901
Phone (800) 798-7398
Hope this helps!
Nov 12, 2008 | Euro-Pro 373 Mechanical Sewing Machine
Euro-Pro X Professional Frozen Slushie Maker Machine
you can find your manual here just go to this url and on the left enter your model...
http://www.euro-pro.com/europro/default.aspx
enjoy.
Sep 26, 2008 | Euro-Pro Dressmaker 998B
Euro pro
Start with the manual....
Dec 28, 2007 | Euro-Pro Fast and Easy 420 Mechanical...
Sewing Machines Logo
78 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
