Question about TENDA A3 150Mbps Wireless Range Extender
Cannot use website to setup Tenda range extender
How do i setup belkin range extender without disc?
I have very old router and don't have its cd.The problem is that i don't know how to setup in my new home.I did some research and find an article which help me a lot for setting up my belkin router in home. http://www.fixotip.com/setup-belkin-range-extender-without-cd/
How To Setup Belkin Range Extender Without Cd Fixotip
Jan 02, 2018 | Belkin Computers & Internet
How do i install my belkin range extender?
restart the belkin range extender . and reset the settings i hope this works
Feb 03, 2015 | Belkin Components Belkin - Dual-band...
Why doesn't my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
Oct 26, 2014 | NetGear N300 Essentials Edition Wi-Fi...
I cant access the 192,168,2,1
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-... Hope i helped you.. great day to you.
Jan 30, 2013 | TENDA A3 150Mbps Wireless Range Extender
How to use tenda w311u
Hello there.
You can download manual here and learn how to use it:
http://www.2shared.com/document/uWKtuOXe/Manual.html
All the best,
Steve TM
May 30, 2011 | Extend Tenda W311U 150Mbps Wireless USB...
TENDA A3 150Mbps Wireless Range Extender Logo
87 people viewed this question
Top TENDA Computers & Internet Experts
David Payne
David Payne
Are you a TENDA Computer and Internet Expert? Answer questions, earn points and help others
