Question about Nordic Track NordicTrack T5 zi Treadmill
My Nordic track T5 zi only beeps 3 or 4 times no matter what button I push and will not start up.
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Posted on Feb 28, 2010
  • 3 Answers
SOURCE: C2155 treadmill 1 1/2 yrs old, Nordic track. Panel
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Posted on Oct 31, 2010
ercupa190
  • 12223 Answers
SOURCE: BUYER BEWARE!! I purchased
Watch this video:
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Check too:Optical Sensor. If have it
Posted on Nov 08, 2011
ercupa190
  • 12223 Answers
SOURCE: How do I disassemble the Nordic Track t5 zi for transporting?
Please read you owner manual.
If you do not have please go to www.nordicktrack. com then customer service and then parts & manual, give you model, etc, and download free and read the section how to fold and viceversa.
sincerely
Posted on Dec 09, 2011
No matter what button I push it beeps3 or four ties.
replace the old batteries ( if your system use batteries, and clean and tight the springs contacts from oxide, dirty, corrosion, use contacts cleaner) .
2) tight and clean the ribbon cables inside from display board, tight and clean the upper and lower connector.
3) adjust the REED switch, tight and clean the connector, and test with multimer for open or faulty see the diagram attached.
Oct 21, 2013 | Nordic Track NordicTrack T5 zi Treadmill
My elite zi will power on but only beeps??
1) you must adjust the REED switch, clean it and tight the wires connector very well.See the diagram
2) when you fix it, RUN the software calibration for diagnose, troubleshooting and fix it.
God bless you
Jul 12, 2012 | Nordic Track NordicTrack Elite zi...
No communication from start stop buttons. cannot get into calibration mode
you must adjust the REED swith, see the diagram attached, clean, and tight the wires connector very well,
Tight the ribbon cable from keypad verywell, and tight the connector from display board vs lower board.Clean the keypad with special spray contacts.
After you fix it. RUN the s. calibration.
God bless you
May 22, 2012 | Nordic Track NordicTrack T5 zi Treadmill
sincerely
Dec 09, 2011 | Nordic Track NordicTrack T5 zi Treadmill
My problem is that my NordicTrack T5 zi is not functioning right. When I turn it on, it has power but once I try to use it, the belt won't go, the screen just makes a beep sound when I push a button....
Now you will have 2 step:
adjust the sensor reed switch, see the diagram.
12_1_2011_5_32_07_pm.gifTight the flexible cable from keypanel vs display board and tigh the connector from display board vs lower board ( main motor controller) and clean the contacts.
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQhttp://www.youtube.com/watch?v=hKbAqvuOBS0&feature=relatedhttp://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Qhttp://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=relatedhttp://www.youtube.com/watch?v=CuMjcPLYehw&feature=relatedhttp://www.youtube.com/watch?v=yX_0vRPdMfU&feature=relatedhttp://www.youtube.com/watch?v=zXeHMWTcLUY&feature=relatedhttp://www.youtube.com/watch?v=dxpOOPetVLoIf after you did this: the problem will be a) Main Motor b) Main Motor Board. see the block diagram.
12_1_2011_5_37_51_pm.gifgood luck, sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Sep 22, 2011 | Nordic Track NordicTrack T5 zi Treadmill
The treadmill is stuck on "incline." Any time we put the red key on it to turn it on, it just keeps moving up and down from 0 incline to 10. It does this over and over again without stopping. No...
I can't solve this, but my Nordic Track T5 zi occasionally does the same thing. The previous two times, I waited until the unit "bottomed out", and then pulled the mag switch (key) off. I unplugged the unit, then plugged it back in, attached the key, and all was well. This worked twice before, but today (3/8/2011)the unit's incline is cycling again, and the old fix isn't working. Maybe it will need to go back to Sears! Unit was purchased in October of 2010. Frustrating.
Jan 30, 2011 | Nordic Track NordicTrack T5 zi Treadmill
I have a Nordtrack viewpoint 3000, the tv will come on and when I touch the start botton it just beeps.
Aug 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
My Nordic Track EXP 1000 won't run.
Has the safety key been inserted? It sound like that what is missing for it to work if that the case call Iconfitness @ 1-800-999-3756.
Part #: 264413
Part Name: ASSY,CLIP,ROPE/KEY
Model: 248110 - NORDICTRACK ELITE ZI TREADMILL
Part List: #264413 - KEY/CLIP
Quantity on Model: 1
Price: $9.82
May 17, 2010 | Nordic Track NordicTrack Elite zi...
Nordic Track NordicTrack T5 zi Treadmill Logo
134 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
