Question about Food Processors
I have a rival FP505 food processor that I used tonight. I have the manual but my problem is we can't seem to get the shaft out to remove the bowl now! Is there a trick to removing the shaft (middle piece)? The bowl will not come off without removing it as it is wider than the opening in the bowl. Please help. I need to be able to wash it! Thanks
    Top Expert:
  • Food Processors Master
  • 12,223 Answers
You must get help from the manufacturer of processor ready your owner manual and go to the website, and see the videos from them and fix it.
God bless you
Posted on Oct 21, 2013
  • 2334 Answers
SOURCE: Sunbeam Food Processor/Le Chef 14-11, 14-1A
Check this website: //http://www.householdappliance.com/food_processor_parts.html
Posted on Jan 21, 2008
xalint1
  • 152 Answers
SOURCE: The plastic ? bowl of the processor is stuck
With the food processor I have it will not allow you to remove the bowl unless the top is off.Try take the top off or putting it on.Then remove it from the processor.
Posted on Sep 22, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Posted on Mar 17, 2009
  • 548 Answers
SOURCE: I got this Shortcut food processor at a yard sale
heres a link to a manual its in adobe pdf file
http://personafile.com/Black-&-Decker-Handy-Shortcut-II-Mini-Food-Processor-HMP60-P0508755200175.htm
Posted on Aug 21, 2009
Cuisinexpert
  • 61 Answers
SOURCE: Cuisinart DLC-7--blade stuck--cannot remove from bowl.
First off, is it a BLADE that's stuck, or a DISC?
If it's a disc, and the disc is blocking your access to the center post, put a ziploc baggie full of ice on top of the disc (right in the middle) and let it sit for about half an hour. That should shrink the plastic enough to pop it out.
If it's a blade, you can try the ice trick, or you can try Pam (or another food grade cooking spray) to loosen it up, and then just try to take the workbowl off like you usually would (aka, DO NOT grab the blade, or you'll risk cutting yourself--you can just pull up on the bowl, and the blade should pop off.
If you need further help, you can always contact Cuisinart--their phone number (according to their website, www.cuisinart.com ) is 1 800 726 0190
Good luck! :)
Posted on Aug 31, 2009
How do I put my rival electric food slicer back together after cleaning it?
final of Rival slicer.wmv - YouTube
? 5:12
https://www.youtube.com/watch?v=miwRiW9R_Hs
Oct 22, 2011 - Uploaded by larry kuberski
This video is a demonstration of the use and safety of a Rivalmodel 1030V food slicer. ... Thank you sir for you your workputting up this video. ... Can anyone tell me how to assembly itback. .... How To Use A Vintage Rival Plastic Fold-Away ElectricMeat/Cheese Food Slicer Model #1044 - Duration: 1:30.
Instruction Manuals - Rival Products
www.rivalproducts.com/.../instruction-manuals.html
The Rival CompanyBeverage · Cooking · Desserts · Food Prep & Choppers · Garment Care ... Shop Rival®Products. Beverage · Cooking · Food Prep & Choppers · Desserts ..
Nov 13, 2015 | Rival Food Processors
Spindle / shaft or mixer bowl?
if you say the motor is running but no blades moves in the cup.it means the shaft which is connected to the blades and the motors break down.
so i refer u to open it and check which shaft part is broken,or take it to the mechanic.
Jan 05, 2014 | KitchenAid KFP740 Food Processor
I can't figure out how to use it.. I just want to make a smoothie!
You can get a manual at WWW. euro-pro.com.
In order to use the blender the food processor bowl and lid must be LOCKED in place. Turn the lid on processor until it's locked. Then you are ready to use the blender. Select desired speed or pulse.
In order to use the processor, remove the blender and place the gray lid in its place. It should be locked. The lid keeps the blender shaft from spinning and allows the shaft on the processor to turn.
To remove the processor bowl, gently lift up on the lid to unlock it and then turn it away from processor. Bowl lifts off. That's it! Enjoy!
Hope I have been of some help to you.
Feb 10, 2011 | Bravetti Platinum Pro Quad-Blade Food...
I have a kenwood gourmet food processor fp305, have had it for years but never got an instruction manual and have never been able to work out how the blades fit on to the central bit, hence, it has...
hi there, I also have Gourmet fp505. No manual. Could I have a copy please if you got one?? I can't use the slicer on mine!
many thanks in anticipation.
C
Jan 06, 2011 | Food Processors
Attachment stuck on shaft of food processor
put the mixing bowl up as much as possible. spray some wd40 into the groove between the attachement and the motor shaft. Wait for several minutes, then with a hammer and a piece of wood, give the bowl a good wack. With a few goes, it will gradually come off. I will be putting some butter inside the attachement from now on to keep it lubricated
Jan 11, 2010 | KitchenAid KFP750 Food Processor
Making Dough
Yes, it is the S-blade. I can't find my manual either and I have been trying to figure out how to get it onto the shaft!! The Hamilton Beach website says it should slip down the shaft once the bowl is attached, but I have a white piece on top of the metal I can not remove and the s-blade will not slip over it.
Dec 03, 2007 | Hamilton Beach Chefprep 70700 Food...
Food Processors Logo
65 people viewed this question
Top Food Processors Experts
eyecam
Are you a Food Processor Expert? Answer questions, earn points and help others
