Question about Mamiya Vintage Auto-lux 35 Camera W/ Sekor 48mm F2.8 Lens W/case & Strap
How to fix the lens, how to open it, need to fix the shooter speed, please someone i will try to explain better if someone knows something
    Problem Solver:
  • 19 Answers
The problem with this Sekor shutter units is that they become stuck by dirt, rust or grease and sometimes is impossible to fix it. In this model the lens unit can be seriouslly damaged if you try to charge it even it is so hard to move.
Posted on Oct 29, 2013
Saeco incanto del luxe coffee machine dumps coffee into waste drawer
Your brew unit may be set in the wrong position inside the machine if someone has had it out to clean or try to fix. The unit has two positions open and neutral when putting back into the machine it should be neutral. This is something I would try first. Now if it is in the open position you will need to reset it. Resetting is better explained on video so I have put a link for a Youtube video. This guy is great and guides you through step by step. Hope this works for you good luck. Please post and let me know.
Cheers
How to Remove Stuck Brew Unit Q
Feb 06, 2015 | Saeco Incanto Classic Espresso Machine
What are the best settings to use the Opteka 500MM Mirror Lens with a Pentax K-7. Also when you you add the 2.0X teleconverter with this lens?
These big lenses are very slow and cannot deliver much light to your camera. Obviously, you can't open the aperture any wider than f8 as specified by the lens itself. In the old days, most inexpensive cameras were fixed focus at f8 with a shutter speed of 1/100 sec. That's a good place to start with this lens without the doubler.
If the pictures are too dark, you can't open the lens any wider so your only option is to reduce the shutter speed.
That means that motion of the shooter or the subject will be more inclined to cause blurring so you need to be shooting from a tripod with a remote shutter release and/or a delayed shutter release setting.
If the test picture is too light, I would first reduce the lens opening to the next stop, f9 or f11, then shoot another test shot. You could also increase shutter speed, or both o reduce the light reaching the camera sensor. Keep shooting test shots until you get the exposure you want.
Once you add the doubler, you compound this situation because it will further reduce the lens speed by about 2 f-stops, meaning that you have to start your tests at f-11 at 1/100 sec. or f-11 at 1/50 sec. This gives you far less flexibility to properly adjust exposure.
Further, you will have increased the magnification so much that a slight breeze or a fly landing on the lens can cause vibration and blur the picture.
Before you shoot any serious pictures, you need to experiment with this lens so that you know exactly what its capability is.
Jun 23, 2011 | Opteka 500mm f8 for Pentax K
Alot of times when i open some sites like "youtube
The internet uses something called DNS. It is similar to a phonebook for the internet, except instead of referencing people to phone numbers, it references IP addresses to webpages.
This error means that someone has purposely removed Facebook and Youtube from the listings in that "book" If you are at a school or workplace, you probably won't be able to fix this without help from a system administrator.
If at home, my suggestion would be to try another DNS Server, or "book".
This webpage explains how to set up an alternative DNS Server
http://code.google.com/speed/public-dns/docs/using.html
Mar 06, 2011 | Facebook Computers & Internet
Xbox360 will not read games
If your XBOX 360 is under warranty just send it back to Microsoft and let them fix it. If not, you need to find instructions on YouTube to disassemble your XBOX and then you will need a cotton swab that has two ends on it like the ones you clean your ears with. Use lens cleaner like you would clean eye glasses with or something that will not streak. Be very careful not to damage the laser. Gently take the swab with the cleaner on it and rub it around the laser lens in a clockwise motion about 3 times. Do the same thing counter clockwise. Now turn the swab around to the dry end and perform the same tasks in reverse order. So...you will use the dry end counter clockwise 3 times and then clockwise 3 times. Now put your XBOX back together and see if it has fixed the problem. There are a couple of other options to try as well but you didn't mention anything about it grinding so I did not post those fixes. Let me know if you need them.
Apr 01, 2009 | Microsoft Xbox 360 Console
MW24FM1 Toshiba Combo...DVD player broken
Try clening the laser lens manually,with a qtip wet with alcohol clean the litle lens then with the dry part of the qtip dry it.Good luck
Jun 17, 2008 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Sanyo vpc-e760 digital camera
i have the same problem ..
it was error 16 AND 21 .
im not entirely sure about the error 27 or any other
numbers ;
but i do know for a fact its because there
is something like dirt ; hairspray ; make up etc.
in the lens .
idk how to take the camera apart ..
but your best luck is to kind of jar your camera with your
palm or a book or something .
mine fell on the floor at first and was fixed ,
but today i dropped it in a little bit of sand and hasnt gone
back down yet .
im hoping i can fix it :/
let me know if any of you have any luck .
Mar 02, 2008 | Cameras
My camra head fell off and now it will not stay on
Don't know if you still have the camera since this is an old post.
It's possible that something got knocked loose inside the camera when it fell. Also possible that that could be fixed but better left to someone who's good at opening up devices with small parts and putting them back together again.
There's a video on youtube (in three parts) where a guy takes one of these cameras apart to tighten the lcd screen and then puts it back together.
http://www.youtube.com/watch?v=Kt4K1X1jITM
If you know someone who's good at that kind of thing maybe they could watch the videos and try to fix the camera.
Apr 29, 2007 | Aiptek MPVR Digital Camera
Lens stuck
If the lens is not coming out, its stuck, or it wont completely open or close, that is the lens assembly, that needs to be repaired. You need to take it to somebody, that can either repair it or replace it for you. There is nothing that can be done, other than that......
Jan 24, 2007 | Sony Cyber-Shot DSC-P8 Digital Camera
Mamiya Vintage Auto-lux 35 Camera W/ Sekor 48mm F2.8 Lens W/case & Strap Logo
90 people viewed this question
Top Mamiya Cameras Experts
Tony Parsons
Tony Parsons
Allen Showalter
Allen Showalter
Level 1 Expert
Are you a Mamiya Camera Expert? Answer questions, earn points and help others
