Question about Targus Chill Mat PA248U Laptop Cooler
How do I clean a targus chill mat - Targus Chill Mat PA248U Laptop Cooler
SOURCE: Targus notebook cooling chill mat.
I have the same problem, and I looked inside to see the cause- the interior part for the power is poorly made and comes loose. That's the reason for the one fan not working and it getting weak. Sometimes wiggling the cord or trying to stabilize it will help. But, as I learned the hard way, it will eventually break. Its a poorly made product, and I've had mine about 4 months now and it completely broke today. I opened it and did my best to stabilize the part, but... it will break. As best as I can tell, its a poorly made product and there is no permanent solution.
Posted on Oct 24, 2008
SOURCE: targus chill mat not working properly
This problem is being caused by a wire becoming disconnected from the switch in the usb power cord. The easiest way to solve this problem is to open the switch using a flat blade like a knife, and either reconnect the loose wire yourself or to completely remove the switch and connect the wires together completing the circuit and allowing the fan to operate. I hope this helps.
Posted on Jun 03, 2009
jan mczeal
  • 632 Answers
SOURCE: Targus Chill Mat Fan On Fritz
The fan rotor is stuck due to accumulation of dust. Take out the fan and clean it. Put a few drops of alcohol or lacquer thinner on the rotor/bushing assembly while manually turning its blades to loosen the hardened dirt until the fan freely spins like the good one. If it does not work, replace the defective fan if spare is available.
Posted on Aug 23, 2009
  • 65 Answers
SOURCE: Targus Chill Mat. I keep getting error with
Belkin makes a surge plug that has usb powered ports.
this is a Gr8 option it takes the poering off the pc.
this should fix ya up.
Good Luck
Happy Computing
Posted on Jan 10, 2010
steve_e_uk
  • 1675 Answers
SOURCE: Lost the targus notebook chill
hi this can be purchased from somewhere like radio shack specs are Output: 5V 2000mA, centre is + positive so really just your standard adaptor will do, this also comes from the targus site hope that helps
Posted on Oct 02, 2010
The little insert in the usb port on my targus dual fan chill mat has become loose. How do I re-insert it and keep it from becoming loose again?
Tawny, If port still functioning, use 2 part epoxy to secure port, be care, no glue inside port.
press the helpful button
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
How do I get the additional usb ports to work on targus awe0101us1 chill pad
Does your laptop recognize the extra USB ports? If no, try updating your drivers.
Jan 15, 2015 | Targus PA248U AWE01US Chill Mat and four...
Laptop chill mat getting lould and fans needs to be cleaned
It will probably be more efficient and easier to replace the cool mat. They are very inexpensive.
Mar 28, 2014 | Targus Computers & Internet
Targus chill mat won't work
it is definatly either a wiring issue or a cpu issue
Mar 18, 2014 | Targus Chill Mat PA248U Laptop Cooler
Targus AWE81US grinding noise in fan
any luck y fans make a grinding noise. vegasguy913@gmail.com
Feb 25, 2014 | Targus AWE81US Chill Hub and Chill Mat...
Targus awe81us disassembly
is it catching on a loose connection, have you damaged the bearings? try youtube .
Jan 26, 2014 | Targus AWE81US Chill Hub and Chill Mat...
Lost the targus notebook chill mat power cord (usb from computer to the mat). Where can I find a replacement?
Oct 02, 2010 | Targus Chill Mat PA248U Laptop Cooler
Targus Chill Mat. I keep getting error with windows 7 that the device is not working properly. It operates but an error keeps popping up every 10 seconds. So I can not use it. What is the fix?
Good Luck
Happy Computing
Jan 10, 2010 | Targus AWE19US Chill Mat XC for Laptops
Aug 19, 2009 | Targus Chill Mat PA248U Laptop Cooler
Computers & Internet Logo
52 people viewed this question
Top Targus Computers & Internet Experts
J John
Laxman Bisht
Laxman Bisht
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
