Question about Electrical Supplies
Lutron maestro - Electrical Supplies
2 Suggested Answers
  • 323 Answers
SOURCE: Lutron Maestro dimmer rocker stopped working
Because the switches are relatively inexpensive, there aren't kits to repair them when they fail mechanically. Your best bet is to get an exact replacement from a Home Depot or such, turn off the breaker switch, and rewire it exactly as it was, using wire nuts and tape.
Posted on Oct 31, 2009
How to fix a broken Maestro Lutron button?
I will take anybody's broken Lutron dimmers.
Please let me know...
Marty
Feb 02, 2012 | Lutron Electronics MAW603RHWH Maestro 3Way...
I replaced a standard single pole light switch with a lutron Meastro dimmer switch with remote. It does not work. I replaced the standard switch and all was good. This circuit is on the same line a gfci...
Hello. There could be a couple of possibilities. First is the simplest to verify, is it a Companion Dimmer, Standard Dimmer switches or a 600W or 1000W Maestro Wireless Multi-location Dimmer. The Maestro Companion Dimmers can not be used individually, as they do not control a load, and must be used along with a Maestro or Maestro Wireless Multi-location Dimmer. The Campanion Dimmers are also a line/low voltage rating, and rated for incandescent and halogen but may not handle some flourescent fixtures. The other thing I can think of is that you may have interfearence from another item. They are radio frequency (RF) devices that communicate together for wireless control of lights. Here's two links that may be of some help, the second has downloadable install instructions.
http://www.smarthome.com/6601LA/Lutron-MA-R-LA-Maestro-Companion-Dimmer-Switch-Light-Almond/p.aspx
http://www.prolighting.com/lumamaprsmre.html
Hope this helps out, don't forget to rate this answer.
Thank You,
Richard
Mar 14, 2011 | Lutron SCR-20-GFCI - Dimmer Controls -...
The LED indicators on my Lutron Maestro continuously run up and down without stopping and the lights (or fan) will not work? It seems as if the entire switch is frozen... Whats the problem?
1) If this installation was working before, the Maestro has a small pull-out circuit breaker that lets you reset the device. This is called the FASS Front Accessible Service Switch, located at bottom of dimmer where it meets cover plate.
Open sample Lutron Maestro dimmer manual to see FASS illustration
http://www.lutron.com/TechnicalDocumentLibrary/0301106A.pdf
2) If this is new installation, then double-check your wiring and check that load matches dimmer capacity: 600 watt incandescent or halogen, which apparently excludes CFLs.
Some electronic devices have shortened lifespan on circuits that are not clean. Use circuit analyzer on nearby outlet that is on same breaker to see if line has interference.
3) Lutron has customer service numbers:
1.888.LUTRON1 (588.7661)
1-800-523-9466
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 03, 2011 | Maestro Lutron Ir Dimmer Mir-lfqthw...
I have a Meastro dimmer MAW-600 W that is installed, but the light does not turn on and the LED keeps blinking. Any idea what the problem can be?
2) If this is new installation, then double-check your wiring and check that load matches dimmer capacity: 600 watt incandescent or halogen, which excludes CFLs apparently.
Some electronic devices have shortened lifespan on circuits that are not clean. Use circuit analyzer on outlet on same breaker to see if line has interference.
3) I don't see MAW-600 W listed among Maestro dimmers, so I don't have that specific manual.
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
4) Amazon certainly shows the MAW-600 W, in case you need a replacement.
http://www.amazon.com/Lutron-MAW600H-WH-Electronics-Maestro-Dimmer/dp/B000BPCWQE
5) Lutron has customer service numbers:
1-800-523-9466
Feb 02, 2011 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Ok i installed the Maestro IR on a switch that runs a celing fan with a light on it. i turned the power back on in the room and the light was flickering and the fan was unresponsive. please help!!
Lutron Maestro IR shows several model numbers:
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro+IR%C2%AE+dimmer
You posted under MIR600 single pole digital fade dimmer for incandescent and halogen.
Installation manual:
http://www.lutron.com/TechnicalDocumentLibrary/030864b.pdf
If this is not your dimmer, then add a comment with exact model number so I can read that manual and look for trouble spots.
The manual does not say 'Fan'
It appears this dimmer is for incandescent and Halogen lights.
Manual gives Lutron 24hr/7day tech support number 1-800-523-9466
If you do not want to add a comment for more free assistance, and do not want to call Lutron, then take advantage of fixya phone service.
Expert will walk you through the problem for a price.
Dec 25, 2010 | Maestro Lutron MIR-600 IR Satin Color...
I have a Lutron Maestro MAW-600 switch connected to 2 pendant lights and the 2 pendant lights bulbs blew. I replaced the bulbs but the lights still do not come on. The Lutron switch flashes green rapidly...
Lutron Maestro MAW-600 manual:
Single-Pole 600 Watt Halogen/ Incandescent Dimmer (minimum 40 Watt)
Lutron technical support 1.800.523.9466
You said pendant lights blew out.
How many total watts were those lights?
Did you remove aluminum break-away fins on side of device to match wattage?
Front indicator can be pulled out to cut power to circuit.
This is called FASS switch.
Try pulling out FASS switch and then pushing it back to see if it re-sets device.
Click breaker on-off to see if it resets device.
You replaced a single-pole switch that has two wires plug ground wire.
Each wire from switch goes to either screw on MAW-600 so it's hard to go wrong there.
Bare copper goes to green ground screw.
Otherwise, it looks like tech support is next step: 1800-523-9466
Nov 24, 2010 | Maestro Lutron MAW-600H Single-pole 600...
How to program control with light switch
If I understand correctly, you have the Lutron Pico wireless control
And you have the Lutron Maestro companion switch or companion dimmer
Pico will not work with ordinary wall switch or dimmer >> it has to be a companion product from Lutron
I have read the PICO wireless manual, and it shows no instructions for communicating with the companion wireless switch or companion wireless dimmer
http://www.lutron.com/Products/SingleRoomControls/MaestroWireless/Pages/Overview.aspx
http://www.lutron.com/TechnicalDocumentLibrary/369-144f_Pico_Wireless_Control_SpecSub%20%286%29.pdf
I have read the 120V Companion switch manual and it shows no instructions for communicating with the PICO wireless control
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Single+Room+Controls&prodn=Maestro+Wireless%C2%AE
http://www.lutron.com/TechnicalDocumentLibrary/030865c.pdf
1-800-523-9466 for technical support
Technical support online appears at page bottom
Normally manuals give you some clue as to how the product works.
The PICO manual says it's easy to control lights (I guess it's easy for mind-readers)
There seems to be no answer or hint when working with the PICO.
I think Lutron tech support is where you go from here.
Let us know what you discover
Oct 22, 2010 | Lutron MRF-VCTX-WH Maestro Wireless White...
Oct 27, 2009 | Lutron Maestro 600-Watt Multi-location...
Lutron Dimmer Probelm
You may want to consider getting an "electronic" dimmer vs. a manual knob or slider. Consider using a Maestro (MA-600-XX where XX is the color). The Maestro fits into a decora opening so you may also want to get a new wallplate (Lutron makes these in a screwless version: CW-1-XX where XX is the color).
Hope this helps.
Aug 27, 2008 | Lutron #D-600PH-DK 600W SP Push Rotating...
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
