Question about Haier Televison & Video
LED TV--Model LEC24B 1380--white screen. no sound. remote won't work! Neither cable of remote from TV.
jmgldsmth
  • 2005 Answers
SOURCE: have a new Phillips 42" lcd tv. my cable box remote has been working intermittently. However the white light near the remote sensor on the TV blinks whenever I use the cable remote. after changing bat
your TV and, your cable box both "see" a series of invisible (infared) flashes of light like morse code these flases tell them what to do.one answer is to: buy a universal remote so that you can program a button for each device then when you want to control the cable box just push the "cable" button and, then volume etc. to turn your tv off push "tv" then "off" the service man was right but he should have explained this to you
also your cable remote may be programable to work with your tv like a universal remote check with your cable co.
Posted on May 22, 2009
  • 304 Answers
SOURCE: NO SOUND ON TV. CABLE REMOTE AND TV REMOTES HAVE
You have just performed the best way to troubleshoot this kind of problem. Check all cables on the back of the tv and your sources and look for any loose or disconnected cables. Next, Hook your DVD palyer to the SAME input that you are using for the cable box. Now if you have good pix and sound then you have a bad cable box. If not then you have a bad Main bd in the tv.
Posted on Jul 17, 2009
  • 64 Answers
SOURCE: new tv - all set up and was working ok. we have
go to menu , sestyme tv and make your system working
Posted on Jan 01, 2011
HDTV GURU
  • 261 Answers
SOURCE: LG LED 4600 - TV
Do you at least get a blue screen? Usually with no picture you get a blue screen. Try hooking up a DVD Player to it and see what you get... Good luck...Keep me posted ..Sincerely HDTV GURU JAY.
Posted on Mar 16, 2011
  • 184 Answers
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Posted on Aug 01, 2011
My samsung cs5038z screen is on video mode sound is ok, when changing with remote to tv no responses, but only sound available but screen still on video mode.
Probably it is a mess in the connection of cables. Do you have the RCA cables ( Yellow-Red-White) , make the connection correct. the TV should be working on RF connector. ( is it connected so ) and what is the sound appears, for the video channel or for the TV??
May 18, 2016 | Samsung Televison & Video
Why is my screen blue flashing "no signal"? My Cable remote does not work TV on/off or volume. Never did. Is there a code for it?
Hi Marilyn
Wow thats a bunch of questions....
I would need a better description to diagnose the problem!
CHEERS
Sep 13, 2015 | Southern Enterprises Seiki SE28HY10 28in...
I have a Philips LCD TV. The remote seems to have stopped working. The TV has power going to it, but I cannot control the volume or select the input with the remote. The controls on the side of the TV...
Take a camera phone and point the remote at the camera, then press a button that you know is working the Tv - you will see a white flash from the remote LED when the button is pressed. If you press a button on the remote that does not work the Tv and you get a white flash from the remote LED when looking at the remote - as if you are going to take a photo of it - then the remote is good and the Tv is faulty. Visa versa, if you don't get a white flash then the remote is faulty.
If the remote is no longer available, then pop it open with a flat screwdriver and wash the remote with a mild mixture of dish washing soap and water. Then let it dry out in the sun until completely dry and then reassemble to try again. I have repaired remote controls in this way for people :)
Jul 31, 2014 | Philips 42PFL3603D/F7 42-Inch 1920 x 1080p...
My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
hi first you will need the proper remote control once you have this press the menu button on the remote, retune the tv hope it helps
regards
shaun
Apr 01, 2014 | Proscan Televison & Video
My tv won't work after I shut it off using the remote throught the cable box
You need to turn on the cable box again. Make sure to select the right source again for your tv.
Jan 11, 2014 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
Atlas ocap
use the camera digital or cell cam and with the remote control viewn see if the LED are ON. see the photo attached.
If do not do it. Open the remote control clean the keypads from corrosion, and resolder any colder joint . clean the contacts batteries and try again.
May 30, 2013 | Televison & Video
Screen went completely white but still have sound
Try with the Mitsubishi remote the soft restart, set on Menu,1,2,3, and enter.
Dec 07, 2012 | Mitsubishi WD-65734 65" HDTV
Masterplug tvr c4n remote(universal)
Try these simple trick to find out your remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
otherwise, the problem with the Remote sensor or related components of the TV.
Jul 13, 2008 | Philips Magnavox Learning Universal Remote
Toshiba TV colour not working
May not be tv, could be cable or sat box. also check cables from sat or cable box.
Craig www.classtorations.com
Jun 08, 2008 | Televison & Video
Televison & Video Logo
15 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
