Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
SM 8525146-A not spinning - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Kenmore elite washer sm 9711034, washer will not go through spin cycle at end of wash cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 19, 2011 | Kenmore Washing Machines
The washer will not go into High Spin. I had the problem before, when a penny was lodged in one of the agitators. I need to know, how to remove the 2 agitators in the washing tub, to remove any debrei
You have to pry off the caps on the tumblers. Try not to produce any burs on them so on reinstall they dont snag the wash load.
Once you have the caps off you take a #20 Torx driver and back out the tumbler retaining screw the SM does not call that out.
Page 37 of the FAV6800A/FAV9800A Service Manual will detail this?
Do you have the SM? If not join this forum and download SM 16022808 Maytag Top Load Neptune Washer Service Manual
Oct 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune top load washer model # fav6800aww will not drain and spin if anything is in it, remove all articles and it will drain and spin
Are yiy failing in Spin Cycle wuth dC or uC error codes?
If so see if this post Clutch Fix. There is a link to the SM.....D*ick
Sep 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The spin motor is going but its not spinning i believe the belt popped off how do i open it up to pop it back on
For the FAV6800/FAV9800AW download the service manual;
5/16 nut driver or 5/16 ¼ socket on an extension to remove front panel see page 41 of the Service Manual
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
As mentioned on page 47 of the SM Roll Drive Belt on the Pulley. (Do not loosen motor bolts). If the belt is broken see Sears Parts Direct for a belt P/N.
Jul 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
