402.4903 te code temperature sensor - Washing Machines
Samsung washer model#wf306law/xaa error code tE - temperature sensor problem. what part do i need
This could be either a sensor or a wiring issue, You need to check the wiring that runs from the sensor to the electronics, the wires can break inside the plastic sleeve and cause the electronics to think there is a sensor fault, It could be a sensor fault but i usually find a broken wire in these machines.
May 10, 2017 | Samsung Washing Machines
Kenmore/MD 4.6 cu. Ft. Front-Load Washer, Blue Silver made by Samsung has a fault code tE. How can I reset the machine?
According to Samsung, tE indicates a temperature sensor issue. The corrective action is to turn off power at the source, wait 30 seconds and start a new program. When that fails, call for service.
Nov 18, 2016 | Kenmore Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Have a error,not LE, but looks like an upside down 7 with a line thru the middle, then E???
often referred to as an 'le' code. looks kinda like an upside down 'F', correct. replace motor position sensor--the hall sensor.
Mar 22, 2015 | LG Washing Machines
TE error code
It means that a temperature sensor is bad, loose or is not sensing water temp because of something. It could be the water temp is wrong
Mar 26, 2014 | LG Washing Machines
I have te error
The thermistor temperature sensor in the machine is faulty and needs to be replaced.
TE = "Thermister Error"
The thermister sensor is connected to the main control board and relays the temperature of the water to it.
Sep 14, 2013 | LG WM2140CW Washer
I'm getting error code tE on samsung silvercare WF316LAS/XAA
tE is mostly related to
temperature sensor wire and connection problem. Look for a broken or loose wire.
Dec 07, 2012 | Washing Machines
I get a te code all the time and a he code from time to time.
from Lg this is the meaning of the codes.
  • The heater circuit has failed if "HE" is displayed. Discontinue use and contact a service technician. The dishwasher requires servicing.
TE
  • "TE" means the thermistor has failed or the temperature of the water entering the dishwasher is over 194 degrees Fahrenheit. Turn the temperature down on the hot water heater in the home. If the error code reappears, replace the thermistor.
    By the sound of this your heating system is malfunctioning and needs service.
    If you need more on this let me know, but it is either your temperature sensor or your heating element or control board.
Oct 02, 2011 | LG 24 in. LD-12BW5 Free-standing...
Samsung front loading washer temperature sensor problem
It may not be your temperature sensor or thermistor. If you have a tE error code on your Samsung washing machine, first check the wiring. My Samsung washer had three visits by the repair tech. and new parts ordered again and again. I looked on a British web site and two people said that it turned out to be wiring broken in several places. Sure enough, I found a broken wire. Technician didn't look for that. Hope it's as easy for you.
Feb 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
