Need gas tank for walk behind lawn mower model #917.377800
  • 205 Answers
SOURCE: Need wheel nuts and bolts for a Ryobi 21 inch
A good hard ware store will have the shoulder bolts you are looking for, take a wheel with you, the solid bolt part should be just a 1/16 of an inch longer than the wheel hub
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: what size spark plug
Champion J-19
Posted on Apr 29, 2009
  • 11 Answers
SOURCE: Could someone please help me
Craftsman.com has an online parts catalog, and will very likely have an online manual as well. Hope this helps. If they don't check out Mowpart.com, or maybe even craigslist.
Posted on Aug 12, 2010
2strokeguy
  • 183 Answers
SOURCE: Need to replace starter cord on Tecumseh LV195EA
This is an easy one. You need a #2 phillips screwdriver, a 1/4" nutdriver or socket, a 5/16" nutdriver or socket, 84" of #4.5 braided nylon rope, scissors and a lighter or flame of some kind.
1. With the #2 phillips screwdriver, remove the 2 screws that hold the green plastic cover to the top of the engine. This is just a decorative cover.
2. With the 5/16 nutdriver, remove the 3 screws in the top of the fuel tank. Lift the tank straight up about 3/4" and then just lay it back on the rear of the mower deck.
3. The round black object on top of the motor is the starter houseing. You will find it being held on with 2 screws from the side. The 1/4 nutdriver should fit these. Remove them, and note the position of each screw and the position of the starter top. It might help to put some colored tape on the starter top and on the upper engine shroud to make sure you put it back in the same position. The starter top will come off by lifting it straight up.
4. Remove what is left of the old rope.
5. carefully wind the inner pulley (the same direction the rope will pull it) until it is tight. Then let it rotate back a little until the rope hole in the pulley lines up with the rope hole in the starter top. Use your screwdriver to hold these in place by putting it through the pulley and starter top vent holes.
6. Measure your rope out to 84inches and then cut it. Take the lighter and melt the ends of the rope to keep them from ravelling. When you melt the ends, take a paper towel or a rag and wipe the ends to form a point. This will make reinstall easier.
7. Push the rope throught the eyelet of the starter top and through the hole in the pulley and tie a figure 8 knot on the inside of the pulley. Tie the starter handle on the other end. but do not tighten this knot, you may have to untie it to lace it back through to where it goes.
8.. Hold tension on the rope and remove the screwdriver. The rope should retract into the starter top.
9.Reinstall everything in reverse order.
Posted on Nov 02, 2010
  • 721 Answers
SOURCE: I need a owners manual
You can look in your local phone book for a SEARS 1-800 number to order just the item you are looking for . They will ship to your home, or if you are near such an outlet you my be able to pick up in your area. You can also pick up any other parts you my need through this 1-800 number.
Best of luck.
Posted on Jun 14, 2011
I have a craftsman walk behind lawn mower with a Tecumseh engine, when the gas tank is filled it leaks the gas into the air filter?
If it is a newer model, it may be equipped with a "carbon recapture" feature in which fumes from the tank are funneled back to the engine via a hose. I had this problem with my DR Field & brush mower and finally disconnected it. When I'd mow uphill with a full tank, gas would flow into that hose and back eventually into the air filter, crankcase and oil. A real mess! However, if your gas cap has little holes (vents) in it, you don't have, thankfully, that reburn system and your problem is something else
Aug 04, 2017 | Craftsman Garden
Why wont my walk behind mower wont start
take your spark plug out put some gas in the chamber replace plug if it fires and not run it is in fuel delivfry check and see if carb. is gummed up if so clean it if not check for restriction in gsas from tank to carb. one of these is the problem
May 23, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Ive replaced my transmission on my walk behind lawn mower it was almost upside down for 2 days ive replaced the gas and oil but it wont start
The gas and oil weren't in the mower when it was upside down were they?
If that's not the issue, then the problem could lie in the fact that neither tank was fully drained before being put upside down. What happens is that the oil and fuel mix and will drain into the wrong area.
My best suggestion would be to leave the mower upright for a few days before trying to start it If need be, drain the oil and gas and let both tanks dry out completely before refilling.
Clean the spark plug and change the filter.
If none of these ideas work, then you will need to take your mower in to be serviced.
Aug 13, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a lawn boy 10335 push mower that sat unused for several years. I added new gas and went to start it up it spring a gushing leak out of the carburator. There is a small red hose that the gas was...
The needle and seat are bad in the carburetor. You need a tecumseh part 631021barterjoe_2.jpg and it might be recommended to get a service manual. They are inexpensive at a shop like www.arcolawn.com
good luck
Joe
Feb 13, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
I'm looking for the manual for the Sears Craftsman II Lawn mower model # 917372850.
Gas-L0709214?brand_name_search=Walk+behind+lawnmower%2C+gas
Attach the above to the other sent link. It was too long to send together
Jul 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
''ariens 21'' self going -or need mix petrol and oil?
you shouldnt need a petrol oil mix in the tank on a lawn mower
May 08, 2010 | Ariens 21 In Classic Walk Behind Push Lawn...
Won't stay running
Check the gas cap vent. A partial vacuum in the tank will cause these symptoms.
Sep 06, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
