Question about Camp Chef Hwd5 Triton Hot Water Heater OC103999
Shuts down and needs to be restarted - Camp Chef Hwd5 Triton Hot Water Heater OC103999
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Have you tried new batteries? Mine lighted fine but would then go out. The batteries provide the spark but they also keep the gas valve open.
Posted on Sep 25, 2017
I have a g6a-6e water heater,it cycles and gets hot then shuts down,and thengoes to the shut down mode.I have replaced the thermo switches and unplugged the fusiable link,restarted and does the same t
Look at front of water heater with cover open. Black rectangular piece of foam under pressure relief valve area, has "therm" and "eco" marked in white letters. Each has 2 male spade connectors sticking out. That is your Thermostat and eco ( emergency cut off) . The ECO basically is a safeguard in case thermostat malfunctions. It is set to shut water heater down, a few degrees hotter than thermostat, just in case. Peel the foam back to expose the Thermostat & ECO, and remove circular retainer to remove either.
Sep 09, 2012 | RTO Atwood Water Heater - 6 Gal LP
Unit periodically shuts off. LED flashes "13."
it sounds like a dirty flame sencer rub down with emrycloth or fine wool steel if that dosent work need new pilot assembly.
Jan 21, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
AO Smith Burner Issues
This system uses an electrical test to make sure that the burner is lit. The flame sensor will either be broken or will be covered in deposits (clean with an emery cloth).
The flame sensor is usually a small metal rod that would be in the direct line of fire of the burner with 1 wire attached.
CAUTION:
The ignitors can be very fragile and are expensive. They are very brittle, do not touch it.
Jun 07, 2010 | Water Heaters
The hot water shuts down for a few minuts then
your unit is undersized or you do not have enough gas supply to run the unit properly.
If you have to many water features running or you have to many gas items turn on at the same time it can cause problems.
Apr 10, 2010 | Rinnai Water Heaters
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Heater shuts down with C4-13 code
your not getting enough fresh air to it. where is it located? you need 1 square inch per 1000 btu's. it's having irregular combusion.
Aug 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Bosch hot water service 16p burner shuts down
a tankleess water heater doen's have a piliot? but check the vent outside make sure nothing is blocking it, if it detects the exhaust thru the cold air intake it will shut off and over heat, other then that it would have to be the control board
Jun 05, 2009 | Bosch & Tankless LP Hot Water Heater
Camp Chef Hwd5 Triton Hot Water Heater OC103999 Logo
93 people viewed this question
Top Camp Chef Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Camp Chef Water Heater Expert? Answer questions, earn points and help others
