Question about Targus Chill Mat PA248U Laptop Cooler
Targus awe19us1 chill pad replacement cord
4 Suggested Answers
SOURCE: targus chill mat not working properly
This problem is being caused by a wire becoming disconnected from the switch in the usb power cord. The easiest way to solve this problem is to open the switch using a flat blade like a knife, and either reconnect the loose wire yourself or to completely remove the switch and connect the wires together completing the circuit and allowing the fan to operate. I hope this helps.
Posted on Jun 03, 2009
steve_e_uk
  • 1675 Answers
SOURCE: Lost the targus notebook chill
hi this can be purchased from somewhere like radio shack specs are Output: 5V 2000mA, centre is + positive so really just your standard adaptor will do, this also comes from the targus site hope that helps
Posted on Oct 02, 2010
SOURCE: I got a Targus PA248U
I opened the case and hard wired the power cord directly to the wires of the fans. There are 4 philips-head screws at the four top corners under the rubber adhesive pads. Separate the top from the bottom. Two wires come from each of the fans. Cut and twist the two positive wires together and the two negative wires together. Cut the end off the power cord that is NOT the USB end and strip the wire insulation back. You will find a white insulated wire surrounded by another wire. Twist the ends of each separately making sure they are separated by the white insulation. Remove the circuit board using the tiny screws where the switch is and put the power cord end through the switch hole. Tie a knot in the cord to prevent cord from pulling out. Make sure the USB end can reach a USB port on your computer. Carefully test which wires to twist together by touching each to see if the fans turn. One way will work and other way won't. When sure of correct wires, you can solder them together and insulate properly with small wire nuts or electrical tape. Reassemble case with screws and plug in USB cord end when you want the fans to cool your notebook computer. I hope that this helps.
Posted on Jul 21, 2012
The little insert in the usb port on my targus dual fan chill mat has become loose. How do I re-insert it and keep it from becoming loose again?
Tawny, If port still functioning, use 2 part epoxy to secure port, be care, no glue inside port.
press the helpful button
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
How do I get the additional usb ports to work on targus awe0101us1 chill pad
Does your laptop recognize the extra USB ports? If no, try updating your drivers.
Jan 15, 2015 | Targus PA248U AWE01US Chill Mat and four...
My Targus cooling pad just randomly stopped working. I got it last month for Christmas so there is no reason for this. It's model number is: AWE57US. I have tried using different USB ports to plug it in. I...
unfortunately I believe typically you cannot return items without the box at least, but one thing I'd suggest is if you can take it apart or find a video on it, and spin the fan since sometimes the barring could be stuck, other than that just to be sure, you should probably buy a new one. Anyways hope I was able to help out in anyway, hope you have a good one
-Jeremiah
Jul 30, 2017 | Targus HD3 Gaming Chill Mat (AWE57US)...
I got a Targus PA248U Notebook Chill Pad, the part inside where I plug the cable in is messed up I think and it won't power on. How do I open it up to have a look to see if I can fix it?
Jan 20, 2011 | Targus Chill Mat PA248U Laptop Cooler
My 17 " Targus chill
Ignore the messages -- you connect it to draw electrical power through the USB port, and that's all you need. It's not like some USB-devices (printers, scanners, et cetera) where getting power to the device is only "half" of the solution.
Oct 29, 2010 | Computers & Internet
Lost the targus notebook chill mat power cord (usb from computer to the mat). Where can I find a replacement?
Oct 02, 2010 | Targus Chill Mat PA248U Laptop Cooler
Targus notebook cooling chill mat. One fan has stopped running after less than 2 months. Can you help
I have the same problem, and I looked inside to see the cause- the interior part for the power is poorly made and comes loose. That's the reason for the one fan not working and it getting weak. Sometimes wiggling the cord or trying to stabilize it will help. But, as I learned the hard way, it will eventually break. Its a poorly made product, and I've had mine about 4 months now and it completely broke today. I opened it and did my best to stabilize the part, but... it will break. As best as I can tell, its a poorly made product and there is no permanent solution.
Sep 28, 2008 | Targus Chill Mat PA248U Laptop Cooler
Targus chill mat not working properly
Oct 30, 2007 | Targus Chill Mat PA248U Laptop Cooler
Computers & Internet Logo
190 people viewed this question
Top Targus Computers & Internet Experts
J John
Laxman Bisht
Laxman Bisht
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
