Model ct962 radio/cassette player - tape will not play,
  • 30 Answers
SOURCE: Tape witll not play
your tape player may be jammed up and not playing your cass.
Posted on Jul 17, 2007
SOURCE: URGENT HELP cassette player problem, please reply
I HAD EXACTLY THE SAME PROBLEM ALL I DID WAS TAKE APART MOVED ALL WHEELS AND COGS IN SIDE AND JUST BLEW OUT ANY DUST CLIPPED BACK TOGETHER AND WORKED FINE PLAYS GREAT HENCE WHY IM LISTING IT ON EBAY.HOPE YOU HAVE SUCCESS
Posted on Sep 14, 2008
  • 4 Answers
SOURCE: Nakamichi BX-2 Cassette Deck Takeup Reel
I had sorta the same problem and I just fixed it. Mine was making clicking noises and jerking the tape causing speed variations and pitch changes, Uggghh. The FF, Rew, and take up functions are not belt driven like most decks. There is a little idler wheel between the motor and the take up axle. Take the whole transport assembly loose from the front of the deck...slide it back 3 inches . Take off the ground wire screw, and 3 screws holding the transport mechanism in place :...1 screw on top, 2 on bottom. Take the black front faceplate off of the drive...2 little screws. This exposes everything.The little idler wheel has a press on tiny,tiny piece of clear plastic holding it onto its little axle. Be hella careful. Use a tiny eyeglass screwdriver to pry it up and off. Dont lose it. Pull the idler wheel off. The rubber has hardened and slips. Pry the rubber rim off of the white plastic pulley using the tiny screwdriver. Put on an O ring that just fits. Scruff up the perimeter of the O ring with 220 sandpaper, Easy does it. Idler wheel goes back in, press on the little plastic retainer, put the black metal plate back on( 2 screws at top), slide the transport mechanism back into the front panel, secure with 3 screws, ground strap, replace cover. Clean heads, demagnetise, badda bing, badda boom.
Posted on Aug 31, 2009
RonPark
  • 855 Answers
SOURCE: An elderly relative has lost a panasonic rq-sx53
Look in your area for any good cassette player they all can play the c90 tapes. All you have to do is have a cassette player. Large stores that have stereo dept. would be a good place to look where you can also hear them to see the sound quality.
Posted on Sep 08, 2009
SOURCE: IT PLAYS TAPES SLOW
can i buy your panasonic rx-dt75. i have that model almost 15 yrs to me made in japan. but this past few months cd and tape do not work... contact me here +639392859269
Posted on Sep 09, 2010
1990 lexus ls400 cassette player will not read or play my cassetes. i put in my cassettes but my front tape flap doesn't close and it automatically switches back to the radio.
The player has to seize the cassette as it is inserted and seat it in the correct position to be played. Sometimes the manual eject linkage becomes defective or misadjusted, preventing the cassette from seating correctly. The eject button may depress fully without causing ejection or it may depress but not cause ejection.
Dec 03, 2013 | Nakamichi 90 94 Lexus Cassette Tape Radio...
Durabrand radio/cassette player model ct962 - tape does not turn when loaded
To be honest I'm not sure about your model. However I have seen the insides of a lot of other tape players, they all use little rubber belts (more like rubber bands almost) on plastic cogs to reel the tape in. My best guess is either one or more of the bands have broken or slipped off their track. The obvious remedy is of course to take it apart and replace the bands, but more than likely it'd be cheaper (and easier) to keep an eye out at a yard sale for another one that works.
Oct 21, 2013 | Audio Players & Recorders
Cassette player doesn't work
tape is in wrong or heder needs to be cleand.
Nov 22, 2011 | Audio Players & Recorders
My cassetteplayeris broke but the front panel says tape unpluged it radio won't play pluged it back in few days later tharadio came back on.going down the road it swithched from radio playing back to tape...
the cage mechanism of the cassete is dropping causing it to shut the radio off ,only solution is to remove the radio and open case then jam the cage into the no casette position with a piece of wood or a folded up cardboard ,i think this will cure the problem
Feb 15, 2011 | Car Audio & Video
I have a JVC (stereo, radio, cassette, recorder) and it's buzzing
If it is only when the tape is running, it could be motor noise.
Worn bearing in the motor or maybe a suppressor has failed, if it has one.
Oct 09, 2017 | JVC RC-EX25 Radio/Cassette/CD Boombox
An elderly relative has lost a panasonic rq-sx53 stereo cassette player. He has many recorded tapes he likes to listen to. Can you advise alternative models which will play these c90 tapes??? The...
Sep 08, 2009 | Audio Players & Recorders
Durabrand Tape/CD Player twists up all cassettes inserted
We have two of these with the same problem. The belt that drives the pick up reels is broken. We are trying to find a place to purchase new ones.
Mar 26, 2009 | Durabrand CD Player with Cassette...
IT PLAYS TAPES SLOW
Jan 06, 2009 | Panasonic Portable Radio/Cassette Player
Cassette player
the tape is very tight
get a pen and try to loosen up the tape
100 % is the tape not the radio
May 15, 2008 | 1999 Ford Taurus
26 people viewed this question
 Grubhead
Grubhead
