Question about John Deere Garden
LA110 only runs with choke
The engine starts in choke, but pulses and stalls when you exit choke. Replaced fuel filter, blew out lines, and blew out carb. Same symptons. Help.
  • John Deere Master
  • 1,169 Answers
Most likely the Nikki carburetor needing a good ultrasonic cleaning and a carburetor repair installed. It would be best for regular lawnmower repair shop to do this as the Nikki can a pain to get the parts replaced correctly and even the new gaskets can leak sometimes.
Posted on Oct 21, 2013
mighty thor
  • 51 Answers
SOURCE: Sputters & quits at proper RPM for engaging trans or mowing deck
If the choke has an adjustment point, then adjust the choke to a good overall working powerband. If it still doesn't act correctly, look for vacuum leaks. If it is an option, you may want to install a manually operated choke lever.
Posted on Nov 24, 2008
SOURCE: gas not getting to carb. Blew out all lines gas, new gas filter
fuel line cracked in shroud just fixed one just like it check fuel line from filter to carb
Posted on Apr 08, 2009
  • 109 Answers
SOURCE: model#917.276020 25hp 48
On the bottom of the carb., there is an anti-after fire solenoid, take it off and make sure that it is working with the key switch, it should retract when the key is turned on and go back out when the key is turned off, if it doesn't check the red wire to make sure it is still connected
Posted on Apr 24, 2009
redbeard00
  • 957 Answers
SOURCE: Craftsman GT5000 W/22hp B+S surges and dies when warm
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
  • 71 Answers
SOURCE: I have a JD 320 hydrowith a Kawasaki FD590V
check all wiring and make sure there are no shorts especialy at key switch also blade and seat safety switchs it could be grounding (question does it backfire at all?) if so is it from carb or out of the exhaust. one more tip the flywheel keyway also servs as a timing pin if it is worn replace it with a new one.. they can cause a multitude of problems if they are worn even the slightest wear can cause it to start hard and other wise run sometimes very well .
point is for under a dollar you can rule it out and possibly eliminate the problem at the same time good luck hope this was helpfull and you can get it going good if i can be of further help e mail me mrdmburns@cableone.net
Posted on May 02, 2009
WHY DOS 2010 HUSQVARNA K750 ONLY RUN WITH CHOKE STALLS WITH CHOKE OFF
Check that the air filter on carburetor is correctly fitted and that the filter element is not blocked. If the filter does not allow air flow it will affect or prevent engine running and by applying the choke the engine will run but it will be using excessive amounts of fuel.
Aug 27, 2014 | Garden
My gmc 4.3 stalls when warm and wont start without ether. then it runs fine
I had the exact problem with my 1993 chevy c1500. I found that the IAC was sticking so the engine would die at idle after warming up and the ignition module was pulsing the ECM intermittently after the engine warmed up so the fuel pump wasn't being turned on after the engine died....I replaced the ignition module and the IAC valve and all is good. I don't know if testing the ignition module reveals that it isn't sending pulses to the ECM.
Mar 28, 2013 | 1991 GMC Sierra
Engine will run only with choke on
you need to take apart the carb and clean the jets inside
Jun 07, 2012 | Garden
Engine surges won't run with out choke and then it stalls
If the engine surges and won't run without choke it is starving for fuel. Best place to start is the fuel filter. After the fuel filter, pull the fuel line off of the carburetor and place a container under the fuel line to catch the fuel. Crank the engine over and watch for the amount of fuel being pumped through the line. There should be a good stream of fuel with each pulse from the pump. Chances are the pump diaphragm is getting weak and it cannot keep enough fuel in the carb to run proper. Check those items and let me know if it helps, Daniel.
Sep 29, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
Small engines
YOU NEED A CARB KIT IN THE CARB IT NEEDS TO BE CLEAND OUT
Sep 25, 2009 | Garden
Engine only runs with choke full on. Dies when off full choke.
Hi Dave, it sounds crazy, but try this. Check your gas cap. It could be clogged, causing a vacuum to occur in the tank, and therefore not allowing the carb. to take on gas. It usually take 10-15 min. for this to occur. The next time you run the mower and it starts to stall out, loosen the gas cap and see if it begins to run again. If it does, then you know that the gas cap is clogged.
Jim
Jun 04, 2009 | Craftsman Garden
Garden Logo
239 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
