Question about Toaster Ovens
Breville oven error code EO1 - Toaster Ovens
Breville smart oven no heat or convection fan. LCD and controls working and can hear the oven clicking on.
The fan probably operated on the heat... I would tackle the THERMOSTATS, heat elements (at least 2) and/or fuse first.
My favorite supplier, appliancepartspros, struck out on Breville
(never-mind) I'll add a couple of credible ones at the bottom.
Sears parts is a good information source... but very pricey ($$$$) for the EXACT SAME PARTS you can get elsewhere...
If you can determine from your OWNERS papers which part you want to try first... get the operating parameters... and and check with a volt meter (ohms scale... power OFF)... for continuity on the FUSE, heaters & thermostat.
There is a possibility your control board (PCB) is at fault... it seems to be getting scarce... Turn it over and look for a burned/broken solder joint.
http://www.ereplacementparts.com/breville-bov800xl-smart-oven-parts-c-116052_116061_116092.html
In any case... get three prices...
In the event that PCB is the issue I do recommend LOOKING TO SEARS because of their parts support and warranty...
Good luck (finding the FUSE).
Breville BOV800XL Smart Oven Parts
Parts and Accessories
Sears Appliance Parts
Mar 04, 2016 | Breville The Smart Oven Convection Toaster...
Breville bov800xl wont turn on. Reset option?.
If the screen turns on and looks like it's working but there is no heat, then the problem is the thermal fuse. It takes reassembly and a $5 replacement fuse. I replaced mine with one of the same specifications and it lasted a month. I replaced it again with one that trips at a 10 degrees higher setting and it's been good for a couple of years now.
Feb 25, 2015 | Breville BOV800XL 1800 Watts Toaster Oven...
WANTED OPERATING MANUAL FOR BREVILLE OVEN MODEL BOV550
Search engine, enter details might even be a download.
Jul 20, 2014 | Breville Toaster Ovens
The Breville BOV650XL will not power on.
I had the same problem with my Breville B0V650XL. It worked fine at breakfast, then wouldn't turn on the next time I tried to use it. Judging by the comments on this site, this appears be a common problem with this and many other Breville products.
I fixed my toaster oven by replacing the thermal fuse assembly. This part costs $4.39 on ereplacementparts.com. It's a shame that an expensive toaster oven is rendered useless by the failure of such a cheap part.
Replacing the thermal fuse itself is very simple - you'll need a small wiring nut and a phillips screw driver. Unfortunately, getting to the part requires removing the oven cover and about 40 screws. A long, magentic scewdriver is essential for parts of this job. It took me about 1 hour to fix my oven - two minutes to replace the fuse and the rest of the time to remove and replace the oven cover.
Feb 25, 2012 | Breville BOV650XL 1800 Watts Toaster Oven...
I need an operating manual for the Breville convection toaster oven
Hi there.
You will be able to find Owner's Manual of Breville Convection Oven at http://www.breville.com.au
Regards.
Jul 11, 2011 | Breville Toaster Ovens
A roach got inside the LCD screen of my Breville oven, and died. Every time I turn on the oven, you see the dead roach. What can i do to get it out. It is so gross. the exterminator came but we have not...
I had same problem. No way to get to inside of LCD screen to get roach out. Took a foil gum wrapper, slid through slots on side of oven by LCD screen. Was able to move roach out of view. Hope this helps.
Mar 12, 2011 | Breville Toaster Ovens
Toaster Ovens Logo
59 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Toaster Oven Expert? Answer questions, earn points and help others
