Question about GE Refrigerators
(GE Refrigerator TFX25JR / TFT25JR) Water is leaking from the chute of the ice maker. The chute is full of ice that has melted and hardened. (Like the warm air in the house is melting the ice?) The ice in the bin is perfect. I thought it may have been a faulty crank or dispenser door flap but I'm not sure. Any suggestion would be greatly appreciated. I am ordering parts tonight and want to make sure I order what I need. Thanks!!
HVACRH20
  • 237 Answers
SOURCE: GE side by side refrigerator ice dispenser
If you take a look at this diagram, you should be able to see all the inner workings of that area and decide if you want to repair it. I think anyone with the most basic mechanical skills could easily handle this repair. See parts 62,63,67, etc. Could just be the spring is off or broken. Let us know what you find! http://www.partselect.com/Schematics/GE/00112435i01.gif
Posted on Jan 08, 2007
lsteward68
  • 331 Answers
SOURCE: Ice Maker is making ice, but The ice from the ice
is the motor is not turning the ice out?
you may need the assembly. go here www.techray1.com and click on the guru guy. this will open repair clinic where you can find the part. pretty cheap
Posted on Jun 16, 2009
Testimonial: "Thank you , Information was very helpful"
aasc
  • 1606 Answers
SOURCE: I would like to order new doors for my GE 25.2
http://www.apdepot.com
Posted on Aug 19, 2009
aasc
  • 1606 Answers
Don't know where my first answer went , but you need the complete model numbers . Go to http://www.apdepot.com where you can find the doors and parts .
Sea Breeze
  • 4654 Answers
SOURCE: have a GE TFX25JR/TFT25JR refrigeratorfreezer fan runs forever
Look inside the fresh food compartment and behind the control panel and there should be a defrost timer. Part number WR9X489 and that is the only reason that I can think of that would keep the fan running all the time. What I think is the contacts that normally open to let the freezer defrost are fused or welded themselves together. If compressor cycles and temperatures are OK (safe) that leads me to that needing replaced. I will look for the wiring diagram for your model but have found it hard to really get those answers from GE. But most timers are universal as long as the time of defrost and hours between are correct, Let me know, Thanks Sea Breeze
Posted on Apr 22, 2010
Testimonial: "Breeze was awesome, and encorauging, i would have given up without the advice, thanks a million Sea Breeze!"
I have a GE Refrigerator that the ice maker keeps getting frozen up, I have changed the ice maker and the water valve out and it has started doing it again now...works good for a couple weeks maybe???
check the ice chute door,where the ice comes out of the door,sometimes the door doesn't close or it's broke,warm air gets up into the freezer and will start icing up everything the air hits,or the door gasket has a tear in it but if it's not water leaking from the ice maker then it's an air leak causing this issue.
Nov 02, 2017 | GE Refrigerators
Why is my ice maker not making ice?
Your pump is probably isn't working. It is in back of frig.
Jul 18, 2014 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
Have a GE TFX25JR/TFT25JR refrigeratorfreezer fan runs forever
Apr 22, 2010 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
