Question about Sony STR-DE475 Receiver
Tuner is not respnding
FM\AM Receiver is not responding. Checked everything and still nothing.
Sound used to be clear. Now have static. Is my pyle PT54 digital tuner bad? I also get a loud hum when the unit is tunred off.
Sorry, but Pyle isn't good gear. If you've checked all the wiring and nothing else has been altered then I'd point the finger at the Pyle-o-c***
Sep 03, 2014 | Pyle New-Home Pt504 Rack-mount Am/fm...
Lost all radio stations on my Sherwood RX4030R
It certainly sounds like the main tuner has failed, if IC301 does that function I would replace it and see what happens.
May 25, 2017 | Sherwood Audio Players & Recorders
Str-de985 humming noise only when using FM tuner. Everything else works fine with no humming noise
Have you got a FM Antena hook up to it for the FM ,Sations, If not that could be causeing it to hum.
Dec 06, 2012 | Sony STR-DE985 Receiver
TEAC AG-V3050 FM reception was fine and then quit. Checked antena with no results. Internal component? Fuse?
If a unit turns on it isn't a blown fuse. Does the tuner give you indications that it is or is not tuning a station? Change the FM Mode to Mono. You should at least be able to hear FM hiss if the tuner is alive.
Jan 20, 2011 | Teac AG-V3050 Receiver
Receiver does not recognize AM/FM signal.
From what I know all receivers need an antenna, there should be a connection in the back for one. Sometimes you can just use a piece of wire if you live in a large city.
Nov 28, 2009 | Kenwood 104AR Receiver
Marantz SR870 tuner not working
Make sure your FM antena connection is good. A receiver will not pick up an FM signal without an antena. Even a small piece of wire will work to test. If the Tuner section is bad, an external tuner can always be connected to an Aux input. Due to cost, it may not be cost effective to repair this unit.
Hope this helps.
Oct 08, 2009 | Marantz Audio Players & Recorders
Will not tune any radio station, fm or am. everything else works fine. May be damage resulting from lightning, through the antena input.
It is very possible the fm tuner pack is damaged from lighting,if you have voltage going to the fm tuner pack im sure your tuner is bad pioneer part number for your tuner is AXQ7231
Sep 26, 2009 | Pioneer VSX-D811S Receiver
Hello all;;;;;; i have a pioneer vsx-9500s,,,,the problem is i ran cable to my reciever so my fm radio will work but it doesn't,,,,,,,,i checked the cable on a tv and it worked ,,,,so i know the line is...
Nonsense. FM is included in MOST tv cable subscriptions- make sure your subscription includes this service. Do you have another receiver/tuner to test with?
Check all the connections between the cable entrance and your tuner; eliminate all splitters for testing. If you can get another tuner to work on your cable, it may be time to check into your tuner-
There is no difference in signal level between tv and fm- your receiver is not gonna burn up! If it has a 75-ohm cable input, use it!
Jan 04, 2009 | Pioneer VSX-D509S Receiver
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card problems
Have you checked the installation? - most PCI capture cards use the audio card of the PC for sound. A jumper cord is needed to come out the capture card and into the audio line-in jack. Green jack on the capture card is OUT, and the Blue jack on the sound card is Line IN.
Jun 17, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Sony STR-DE475 Receiver Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
