Question about ECHO, Inc. PB-251C Handheld Blower
Runs on idle,bogs out when given gas - ECHO, Inc. PB-251C Handheld Blower
No Check Engine Light illuminated, when I press the gas it bogs down and will not exceed 3000 RPM. No powere
Millage, make , model ......
Catalytic converter clogged ?
I could guess all night but need more info.
Feb 09, 2015 | Cars & Trucks
Scooter runs but bogs down when given throttle 2007 triton vento scooter will run bogs down when given throttle
Make sure the air box is installed and the snorkel is on the air box and that it's in good condition. They don't run well or sometimes at all beyond idle without the air box. Could also be a clogged main jet or otherwise dirty carburetor.
Oct 26, 2013 | Motorcycles
Ttr90 bogs down at high rpms
I have a ttr 90 that idles well but bogs down at full throttle. Carb is clean and has new pilot and main jets. Seems to run slightly better with intake off. Which leads me to believe the mixture is rich. No adjustment on carb. Stumped?
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
May 28, 2012 | Yamaha Motorcycles
Blower runs at idle then when you give it gas it bogs down until it shuts off
try to choke it part way and see if it still bogs down, if it does then check your exhaust screen, if partial choke helps it then check fuel lines for cracks, fuel filter for being dirty and also remember fresh gas too, if all else fails clean your carb out.
Nov 19, 2011 | Garden
85 xj700 runs rich, terrible mileage, and "bogs
Is there an air fuel mixture adjustment screw? I'd try lookin for one and adjust it a little and see what happens. Sounds like your mixture is way too rich. A more lean mixture won't bog down, but too lean of a mixture will bring your idle speed up too high
May 28, 2011 | 1985 Yamaha XJ 700 S Maxim
New top end- now does not idle-bogs out when given gas
Sounds like an issue with the choke not opening.
Nov 25, 2009 | 2003 Yamaha YZ 125
Throttle bog out
hi,this may help,check the inline fuel filter and the air filter,if it has been sitting that long the fuel filter may have gummed up(a slightly gummy residue left behind after fuel evaporates) the engine will run ok at low and medium throttle but the filter will be quite restrictive once the load goes on,change the filter and clean the air filter and you might find the problem disappears...hope this helps...cheers
Jul 28, 2009 | 2001 Yamaha WR 426 F
92 dodge b250 van idles fine in drive bogs when given gas
Hi! Just a quick thought, I had a similar problem on a GM Astravan and the Catalytic Converter was totalled, I pushed a screwdiver through the inside and Bingo better than ever.
Jan 06, 2009 | 1993 Dodge B Series Cargo
ECHO, Inc. PB-251C Handheld Blower Logo
19 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
