Question about Oster Microwave Ovens
Oster microwave model OGYM1602 turns on but is not heating.
SOURCE: oster Microwave Model GOB 61101
The fuse in the white jacket ( 0.85 amp) is blown. Easy fix but unplug and watch out for the cap. It's located on the right back side between the transformer. The fuse looks like the old car glass buss fuses.
Posted on Nov 18, 2010
rickead1
  • 1998 Answers
SOURCE: Oster 1.1.cu.ft countertop microwave model
check the high voltage fuse on the inside of the unit if this is not showing a fault then you would most likely be looking at replacing the magnetron in your unit this is the most common piece beside the fuse that shorts out and is what is directly realted to what is actually heating your food depending on what type of microwave it is it may be cheaper to just buy another microwave if the place of origin on the microwave came from a walmart or target store where as buying a magnetron may cost you between 50-100 dollars which is about the price of a micro wave at one of these stores if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks Rick
Posted on May 23, 2011
valdezrene81
  • 7 Answers
SOURCE: Hi, I have an Oster
I bought-the oster microwave and like others it did not last long before it stop heating. I took (careful precaution!!) and (unplugged the the unit!!) to view the fuse which of course is the main problem why this microwave does not heat up. Everything else works well but the heating. But since I changed the fuse to something very close to the same amp of the actual fuse it did work fine next to nothing.
I did not find any problem other than the noheating. This should only be attempted by someone who is in fact has close knowledge of electricity. The process is safe (WITH THE CORRECT PRECAUTION!!).Ever since I replaced the fuse and found out that that was all it needed I have been using it for 8 mths. Note--I did take measures into my own hands which is not recommended by anyone. But it is the old-fashion way...
Posted on Sep 14, 2011
  • 8404 Answers
SOURCE: My Oster microwave (model #OGG21401)
Check the door safety interlock switches for proper operation. #1 trouble with microwaves that operate in all respects but no heat.
Thanks for your question @ FixYa.com
Posted on Sep 16, 2011
  • 6771 Answers
SOURCE: oster microwave OM1101NOE wont heat light comes on and carosel turns
There are a few possibilities, magnetron, high voltave diode" sometimes cracks" high voltage capacitor " shorts"
Posted on Mar 09, 2012
My oster microwave is not heating. it lights up, and it spins but no heat
The unit that makes microwaves no longer working. It has a separate fuse for it. There is a hi voltage transformer there too, It may be bad
Jul 28, 2016 | Oster Microwave Ovens
Oster microwave starts when door is closed but no buttons pressed
This is usually caused by a door switch that has come loose or out of adjustment.
Jul 19, 2014 | Oster 0.7 Cu. Ft. Countertop Microwave -...
My oster microwave ogb81005 want heat up
I prefer the Oster OGZB1101 microwave , it has more features, definitely worth checking out.
Jan 18, 2013 | Oster Microwave Ovens
My Oster OM1201eovg microwave will turn on but it won't heat what I put in there. What's the problem?
Either the inverter which powers things or the Magnatron which in effect does the heating are bad.
If a fairly expensive unit it may be worth repair as these are of course two of the more expensive parts in the unit.
Sep 04, 2012 | Microwave Ovens
Oster microwave OM1101NOE wont heat light comes on and carosel turns
Mar 08, 2012 | Oster OGB61101 Microwave Oven
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
My Oster microwave (model #OGG21401) doesn't heat. When operating the light will turn on and the carousel will turn but food will not get hot. Can you provide a solution to my problem? Thank you.
Sep 16, 2011 | Oster 0.7 Cu. Ft. Compact Microwave
I am looking for a door latch part for an Oster OGB81201 microwave oven. Does anyone have any ideas?
model OGB81201; oster microwave, called the service # posted earlier. was told that the model i had is "not serviced by this dept. " only units beginning with OMW####
Aug 29, 2011 | Oster Microwave Ovens
Microwave Ovens Logo
57 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
